Author Topic: 82 cb650sc vb44c pilot screw adjustment help  (Read 5384 times)
Offline cmouta
« on: October 25, 2012, 05:32:30 PM »
I tried to dial in my mixture today following the clymer manual and I think I'm an idiot. Can I explain what I think the manual is telling me? It seems like I'm just riching the hell out of my engine and running it hot.
Page 206
3. Lightly seat pilot screws, 1.5 turns out
7. Set idle to 1050+-50 with idle adj screw
8. Turn each pilot screw out 1/2 turn from step3 setting. (All of them???)
9. If speed increases by 50rpm or more, keep turning out by a half until rpms drop by 50( why would it eventually drop 50rpm if i keep enriching it? Wouldnt i just achieve max idle? again, all four at once? I was doing all four at a time and speed kept increasing and the oil I'm leaking from head really starts smoking so I quit and go back to 1.5turns)
10. Adjust idle screw to 1050rpm (if I'm supposed to be doing Max idle 1 at a time, do I do this after each Max idle Carb adjustment or after all 4 reach Max idle)
11. Turn no.1 pilot screw in(lean) until speed drops 50rpm
12.turn out 1 full turn
13. Adjust idle to 1050
14. Repeat 11-13 for other carbs
« Last Edit: October 25, 2012, 05:34:13 PM by cmouta »
Chris
1998.5 Black Ford Contour SE V6 MTX
1988 Mono Rosso Red Merkur XR4Ti T5 MT
1982 Candy Flair Blue Honda CB650SC Nighthawk
Offline tomkimberly
Re: 82 cb650sc vb44c pilot screw adjustment help
« Reply #1 on: October 25, 2012, 08:34:56 PM »
The idle screw on the VB44 carbs meters the air, not the fuel.
As a rule of thumb, idle screw in front of carb, air metering, idle screw at rear of carb, fuel mixture.
On my 650C, I did a bench sync using 1/8" drill bits, set the idle screws to 2-1/2 turns out, and left it at that. It runs great.
Tom
Offline cmouta
« Reply #2 on: October 26, 2012, 06:15:48 AM »
Tom
Thanks for the input Tom.  I've read so many different things on the topic, I must have gotten mixed up somewhere but that makes sense.  Turned the screws out, more air, leaned out the engine, started running hot.  I could have sworn though that, generally, pilot screw on the engine side = fuel mixture adjustment.
from the carb faq:
"What happens when I turn the airscrew out - richer or leaner?
If your airscrew is on airbox side of carb, turning out will lean mixture; opposite if airscrew is on engine side of carb. "
my VB44C's being on the engine side, turning them out would allow more fuel and run richer which i think is confirmed in the '82 high altitude adjustment supplement of the clymer manual which has you turn out .5 turn from lightly seated initially, resulting in a leaner condition.
honestly I think the bike has been running fine since i got it running with the initial 1.5 turns out but I know so little about bikes I want to make sure it's as perfect as possible.  Maybe I'll go for a good ride and pull the plugs and check them.
« Last Edit: October 26, 2012, 07:11:22 AM by cmouta »
Chris
