Author Topic: CB400F Engine Paint  (Read 2122 times)
Offline Lynx
CB400F Engine Paint
« on: October 26, 2012, 04:12:32 AM »
I put my CB400 bits into Redditch Shotblasting yesterday for a good clean up. They were quite keen to powdercoat the whole engine. I am planning to spray it myself in aluminium engine enamel to keep the cost down. When I was explaining that as standard it was all painted silver except the barrels, they said "Why weren't the barrels painted as standard?" They also said they have powdercoated the barrels in the past. So my question is, why weren't the barrels painted by Honda? Heat dispersion/just appearance?? Or am I wrong in that respect?
Cheers
1976 Honda CB400F
Varnish Blue
Standard build
In preparation
Offline mono
  • Definitely no
Re: CB400F Engine Paint
« Reply #1 on: October 26, 2012, 04:20:23 AM »
Many argue that it was for better cooling.  I've never heard a definitive answer though.
Sent from my SPH-L710 using Tapatalk 2
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: October 26, 2012, 04:24:46 AM »
I would not powder coat an engine, way too much preparation to do it properly. Plus, it theoretically could reduce cooling.  Mono is correct-at least that is what I always heard....Larry
oldbob
« Reply #3 on: October 26, 2012, 09:00:09 AM »
My 400's PO painted the barrels and the paint is peeling off. Admittedly, he probably spent no more than five minutes doing surface prep. Eventually, I'll strip them completely.
Bob
Offline RickB
    • Pop Magazine
« Reply #4 on: October 26, 2012, 02:07:06 PM »
This website has some great information on the original Honda paint scheme:
http://www.cb400f.btinternet.co.uk/engpaint.htm
Personally, I had mine hydro blasted and haven't regretted it:
http://forums.sohc4.net/index.php?topic=91540.msg1023226#msg1023226
Rick.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #5 on: October 26, 2012, 03:30:29 PM »
You don't say how they prepared the cases but their title says 'shotblasting', be very careful there are lots of horror stories about shotblasting engine cases, the grit gets everywhere including oilways, that can mean a destroyed engine, the same can go for powder coating as the powder is electrically charged and drawn to the metal, personally I would go with the spraycan and good masking.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
