Author Topic: Project: 7-Fizzle - V1.1 - If only spring would get here...  (Read 147676 times)
Offline iron_worker
Re: Project: 7-Fizzle built in the Man Room!
« Reply #225 on: January 28, 2013, 02:22:12 PM »
Thanks for checkin in everyone. It's nice to see people are appreciating my efforts. ha
IW
Offline iron_worker
« Reply #226 on: January 28, 2013, 06:56:52 PM »
Another small update:
Got a call from my bead blaster and my engine cases and hubs are done. I'll be picking them up tomorrow afternoon.
Also got a call from Ken at CycleX and he says my work is moving along well. Crank was out of balance by 6g but now has a good of a balance as their drag bike crank does. Nice. Head and cylinders are blasted and resurfaced. He has new guides in but still needs to finish the valve job. He was just finishing boring/honing my cylinders as he called me. Should be done this week. Woo!
Just ordered this from David Silver Spares:
1 x 9410106000 - Brake caliper adjuster bolt washer (£0.50) - £0.50
1 x 45522300010 - Brake master cylinder boot (£4.95) - £4.95
1 x 43513469611P - Brake master cylinder cap (£6.95) - £6.95
1 x 9501016001 - Clutch lever end rubber (£2.75) - £2.75
1 x 9501016001 - Brake lever rubber, Front (£2.75) - £2.75
1 x 30203300154 - Contact breaker / Points for cylinders No.1 and 4 (£21.00) - £21.00
1 x 30204300154 - Contact breaker / Points for cylinders No.2 and 3 (£21.00) - £21.00
1 x 18291MM5860P - Exhaust port gasket (£1.25) - £1.25
1 x 17514323300P - Fuel tank cap pivot pin (£2.95) - £2.95
1 x 17513300300P - Fuel tank lock pivot pin (£2.95) - £2.95
1 x 31110300154P - Generator wiring harness (£29.00) - £29.00
1 x PMIR 10MM - Mirror set in Chrome (£16.00) - £16.00
1 x 15412300PACKP - Oil filter 5 pack (£14.00) - £14.00
1 x 15150300000 - Oil strainer screen (£11.95) - £11.95
1 x 90141300000 - Oil tank mounting bolt (£4.25) - £4.25
1 x 9410108000 - Oil tank mounting bolt washer (£0.50) - £0.50
2 x 87123341673P - Side panel emblem 750FOUR (£16.50) - £33.00
4 x 90313567000 - Side panel emblem retaining clip (£1.40) - £5.60
1 x 87126341000P - Side panel Wing emblem on Orange background, Left hand (£14.95) - £14.95
1 x 87127341000P - Side panel Wing emblem on Orange background, Right hand (£14.95) - £14.95
1 x 44712300004P - Tyre inner tube for Front wheel (£5.95) - £5.95
1 x 42712300004P - Tyre inner tube for Rear wheel (£5.95) - £5.95
1 x 44713MR1671P - Wheel Rim tape for Front rim (£1.50) - £1.50
1 x 42713304003P - Wheel Rim tape for Rear rim (£1.50) - £1.50
1 x RIMSM 185 19 40 - Wheel rim, Front - 1.85x19 40 hole (£29.00) - £29.00
1 x RIMSM 215 18 40 - Wheel rim, Rear - 2.15x18 40 hole (£29.95) - £29.95
1 x PSPO 44606-300 - Wheel spoke kit for front wheel (£29.95) - £29.95
1 x PSPO 42606-300 - Wheel spoke kit for rear wheel (£29.00) - £29.00
1 x 17211405000P - Air filter (£8.95) - £8.95
1 x PWINK 292 - Indicator / turn signal assembly (£5.95) - £5.95
1 x 15410426010P - Oil filter (£3.50) - £3.50
Total: £362.45 (delivery is gonna be a b!tch from the UK)
Also just bought a grab rail off a member from here.
The good: Parts on the way! Also, this should be last major expenditures other than paint I hope.
The bad: How am I gonna pay for all this #$%*!? lol
My CC is on fire! Someone get an extinguisher!
IW
« Last Edit: January 28, 2013, 07:04:44 PM by iron_worker »
Offline vfourfreak
  • Do you think that's wise
« Reply #227 on: January 29, 2013, 12:54:20 AM »
Has David Silver commenced shipping from his US depot ? I see they are maintaining two separate web stores www.davidsilverspares.co.uk and www.davidsilverspares.com . Looks like they won't ship from the US to Europe, yet will the other way around ??
Have you put that fire out yet ?
Kev
Offline iron_worker
« Reply #228 on: January 29, 2013, 05:52:06 AM »
Well I emailed and asked for a shipping quote when I was just considering rims and spokes and they do ship from the Europe to Canada.
I didn't realize there was a US store... guess I should have looked around a bit more. I might have just got owned on shipping.
Checked the .com website ... yep they definitely ship to Canada... OWNED!
IW
« Last Edit: January 29, 2013, 06:50:23 AM by iron_worker »
Offline Garystratos201
  • I have never been a
« Reply #229 on: January 29, 2013, 01:43:33 PM »
IW have tried ServiceHonda.com ? They have the best prices I`ve found so far and reasonable shipping also. Everything I have checked against David Silvers prices were a good bit cheaper and so was the shipping. ........Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline iron_worker
« Reply #230 on: January 29, 2013, 02:20:39 PM »
I have tried Service Honda. Although they have good prices their shipping to Canada is pretty outrageous. I will have to try the American David Silver Spares in the future.
Here is something I picked up today:
They masked and plugged all the holes as I asked. I more or less just assembled the cases with no internals and all the covers and had them mask and plug all blind threaded holes and any holes that led to the inside.
The glass beaded surface should accept paint very nicely.
All the nooks and crannies are clean and new again!
The bead blasted hardware should accept zinc very nicely.
Hubs looking nice as well.
Some cryptic markings that I'm not too sure what they mean.
I had them do both sides of the valve cover and breather cap. I hope it doesn't affect the sealing of the gasket.
I think the parts look really nice and I'm pretty stoked to paint them. I would actually just keep them this way if I knew it wouldn't oxidize like crazy. I really like the clean white/matte look. Would really make the chrome exhaust and chrome starter cover/ignition cover pop next to it I think.
I also recently discovered that my right hand control is from a 77-78 model. This explains why all the connectors were cut off and I found a section of bundled wires going to nothing inside the handle bars.... I really didn't want to mess around with customizing my brand new wiring harness so I ordered this today:
1 x   Bar Switch Assembly ~ Right (Brake) Side (12-0301)   US$69.95
1 x   Bar Switch Assembly ~ Left (Clutch) Side (12-0300)   US$69.95
1 x   Cable Adjuster (08-0067)   US$2.50
1 x   Right Angled Snap Ring Plier Set (35-0009)   US$14.95
1 x   Tire Lever - Fusil Type (35-0079)   US$9.95
1 x   Terminal Crimper Tool (35-0011)   US$28.00
1 x   Metric Terminal (12-0120)   US$2.00
1 x   Coupler Set (12-0634)   US$4.00
1 x   Metric Terminal (12-0121)   US$2.00
1 x   Metric Terminal Cover (12-0027)   US$2.00
1 x   Metric Terminal (12-0024)   US$2.00
1 x   Metric Terminal (12-0023)   US$2.00
1 x   Metric Terminal Cover (12-0019)   US$2.00
1 x   Metric Terminal Cover (12-0125)   US$3.00
1 x   Metric Terminal (12-0018)   US$2.00
1 x   Metric Terminal (12-0017)   US$2.00
1 x   Metric Terminal (12-0124)   US$3.95
1 x   Metric Terminal Cover (12-0022)   US$2.75
1 x   Metric Terminal Cover (12-0020)   US$2.00
1 x   Metric Terminal (12-0021)   US$2.75
Sub-Total:   US$229.75
Free Shipping (FedEx Ground®):   US$0.00
5% PST #83590 8898 RT0001:   US$11.49
5% GST #83590 8898 RT0001:   US$11.49
Total:   US$252.73
I had planned on restoring my existing controls but knowing that at least one of them is not correct and I would have to hack up my wiring harness made me jump ship. If anyone needs a right hand control for a 77-78 let me know! lol And also I believe the left hand control fits 72-78 ... I think?
There is no backing out of this project now. ha
IW
Offline cheftuskey121
  • Super Newbie
« Reply #231 on: January 29, 2013, 02:53:23 PM »
cases look great man! seeing that makes me smile because that VHT nu caast aluminum paint I have looks EXACTLY like those fresh cases. I just painted my front hub, caliper swingarm, and oil filter cover, and its almost 100% identical. it has the brightness to it that other engine silver paints I've seen here don't. I know you said you already have your paint but this was only $23 for two cans with shipping I believe.
Offline iron_worker
« Reply #232 on: January 29, 2013, 06:50:04 PM »
I've arleady done the forks in the duplicolor so I think I'm stickin with it now to tie it all together.
IW
  • Super Newbie
« Reply #233 on: January 29, 2013, 07:31:04 PM »
gotcha, did you put up pictures of the forks? good to know you painted them. I want them polished but I sure am not doing it, so I would rather paint them :D
Offline brandEn
« Reply #234 on: January 29, 2013, 07:56:08 PM »
Hey be CAREFUL when you try to remove those valve tappet covers if they were blasted while installed. I had a few stuck ones on my cover. I had to drill one out to remove it. The media can work its way into the threads and make it nearly impossible to remove the covers.
Offline iron_worker
« Reply #235 on: January 30, 2013, 06:00:39 AM »
Good to know. Will do.
Thanks
IW
Offline iron_worker
« Reply #236 on: January 31, 2013, 06:20:05 PM »
Some pics that I got from CycleX. Should be working up my invoice and packing it all up to ship to me.
Sorry about the small pics but that's what I got! I'm excited to get my stuff back!
IW
Offline brandEn
« Reply #237 on: January 31, 2013, 06:21:49 PM »
WOW that's a great turn around time. I have always had great service from Cycle X too. Parts look great!
Offline iron_worker
« Reply #238 on: February 01, 2013, 05:50:08 AM »
I'm thinking since my order was fairly large they were pretty motivated to get it done and get it billed to me. ha
But I really can't complain with their service at all. They called me when they received my package, gave me a couple updates along the way, and let me change my order a little bit during with no problems. I'm pretty happy. And although I spent a small fortune with them I actually got a lot of parts and work for the money.
IW
Offline vfourfreak
« Reply #239 on: February 01, 2013, 06:23:56 AM »
Sounds like they are giving you a better deal than the broken stud removal man !
Kev
Offline JC Blues
  • HOWDY!!
« Reply #240 on: February 01, 2013, 08:06:17 AM »
IW I really love your build!! Best example of using what you got!  :D
Offline iron_worker
« Reply #241 on: February 01, 2013, 10:57:31 AM »
Thanks guys. And ya I probably should have sent my cases to them to pull the stud out. May have been cheaper! lol
IW
Offline vfourfreak
« Reply #242 on: February 01, 2013, 11:07:31 AM »
Hey IW, we all learn along the way . . thanks for sharing what you have learned, certainly I am now approaching my Nickel plating kit with more confidence. Thank you.
Kev
Offline iron_worker
« Reply #243 on: February 01, 2013, 12:47:04 PM »
I hope it goes well for you. Make sure to post pics either way! lol
IW
Offline iron_worker
« Reply #244 on: February 02, 2013, 01:39:11 PM »
Welcome to my murder room... lol ... looks like something from Dexter.
Well I got all my parts prepped for paint as well as all the plastic hung. Once again the taping took wwwwaaaayyyyy longer than you would imagine it would. I was first going to try and paint it all with the covers on but then my OCD kicked it and said that wasn't good enough. So I took all the covers off which means you have to tape the backside of each cover as well as each place that the cover was ...umm ...covering.
Tip: Lay your tape down so it covers the whole surface and then go around the edge with a mallet and gentle tap coming down on the corner. This will make a nice line for the tape to tear along.
Tip #2: Wipe everything down with varsol or some type of thinner to remove all the oils FIRST. I tried taping some things first but it didn't stick well in places because of residual oil.
I got shut down before I actually got to paint since I managed to give my gf a massive headache with the smell of the varsol... Even though I had the door closed and fan on exhaust on full. She is hyper-sensitive to smells like that which makes stuff like this pretty difficult for me sometimes. I may have to send her away for a couple hours tomorrow so I can spray some paint. The actually spraying shouldn't take too long now that all the prep work is done. I hope ...
IW
Offline bjbuchanan
« Reply #245 on: February 02, 2013, 07:39:29 PM »
Put that rear brake pedal on now while you still can. Once the engine is in place or you start putting more parts on you will hate yourself. If the arm gets in the way just pop it off. That spring will be a beast to manipulate with all the crap that gets in the way. I learned the hard way
Offline iron_worker
« Reply #246 on: February 03, 2013, 12:11:39 PM »
Good to know. Will do. Thanks.
No painting today. Off to an out of town funeral for my grandma today.  :( :'(
Oh well. The bike can wait. Time to support my family.
IW
Offline iron_worker
« Reply #247 on: February 06, 2013, 07:50:24 PM »
After what seemed like an eternity of my parts just hanging there and my room all taped off like a murder room I finally got back at painting. Should be the last bit of painting I should have to do besides my gauges.
Don't I look ravishing (or crazy?) in my safety gear.
Parts have been hanging like this for almost a week.
Coat 1...hard to even tell the difference. This is good. It means that the duplicolor is a close match for the natural clean color of the aluminum.
This piece seemed to go on with a bit of "hammered" look but seemed to smooth out with more coats.
Coat 2.
Startin to get a nice finish.
Some imperfections but those were in the base metal itself.
An ever so slightly textured finish that is exaggerated by the flash.
While waiting for parts to dry lets check out some parts from vintagecb750.com. A bunch of connectors to fix up my electrical, the proper cirmping tool (I looked at buying a die for my existing crimper and it was actually more money?), some long snap ring pliers for the master cylinder rebuild, another tire iron, and brand new repro controls.
Not quite the right anodized look but I'm OK with it since I was going to repaint my old ones anyway. I found out my right hand control was from a 77-78 750 and that is why my wiring harness was so hacked up. I wasn't about to hack up my brand new harness so I just broke down and bought new ones.
Looks like I'll have a pair of original controls for sale soon. lol
Coat 3 finished.
Wait an hour for the parts to dry enough to be able to move them. This paint actually seems to dry to the touch quite quickly. Painting in the condo with the low humidity of winter probably helps too.
The results.
As I said previously, the hammered look mostly smoothed itself out. Quite pleased with the results.
Batch 2 ready to go.
Coat 1 looked like sh!t. It seemed to come out in blobs. WTF? This was a different can btw.
It left a texture on everything.
I thought it might that with the fan on the room was starting to cool down quick so I put the cans in some warm water. However, it kept coming out in blobs. ARG! I even tried a different nozzle. Finally I tried a different can entirely and it worked fine. Conclusion: don't try to save a sh!tty can of spray paint. Some are just bad! Don't be cheap and throw the f*cker out.
Fortunately coat 3 with the properly working can seemed to smooth out the imperfections.
I didn't spend much time prepping the starting so it wasn't perfect but seeing as it will be under a chrome cover I'm not too worried about it. lol
Pretty glad to get this step done. Feels like now that pretty much all the parts I need are on the way all that is left is pretty much just reassembly ... and lots of it!
I'm glad that the paint turned out well. It is a close match to the true color of clean blasted aluminum and I think it will be a nice low maintenance solution. It should also make the chrome bits pop really nicely as well.
IW
  • Super Newbie
« Reply #248 on: February 06, 2013, 08:59:54 PM »
Iron. Great job painting! It all looks GREAT! Really makes me want to just paint my whole engine and not mess around with the polishing game. Definitely leaning that way but I want to see yours all assembled. Get to work! Haha can't wait for more updates. I am at a crossroads whether to take my engine apart or not. Never done any of this before and it DID run before year down, I just don't know if I should try and tackle this or if it would set me back more than I need it to now. Decisions decisions.
Offline iron_worker
« Reply #249 on: February 07, 2013, 05:57:34 AM »
Thanks!
Ya I think I'm making the right choice by painting it all ... and even if I change my mind later there is always a winter or two or three down the road that I can choose to go buck wild on the polishing if needed. It's not like it's irreversible.
My engine was running pretty well when I took mine apart though lacking some top end it seemed. I found a broken ring on #2 piston so I'm pretty happy I decided to go all the way and rebuild it. However, it has added *significant* expense to the build. Roughly half the cost of my bike restoration is in the engine. So just consider that.
If you want to go for it anyway, that's cool too. There are tons of guys on this forum doing the same thing and lots more with a huge amount of knowledge that will help out.
IW
