Author Topic: Project: 7-Fizzle - V1.1 - If only spring would get here...  (Read 147667 times)
Offline vfourfreak
  • Do you think that's wise
Re: Project: 7-Fizzle built in the Man Room!
« Reply #275 on: February 13, 2013, 11:47:27 PM »
Perhaps the salt in the dishwasher afected the surface of the cases ?
Offline CROMOLY
« Reply #276 on: February 14, 2013, 05:13:15 AM »
Keep up the good work, still trying to figure out your zink plating device of yours,
Have fun with your motor.
Cromoly.
Wish it was made out of Lego
Offline iron_worker
« Reply #277 on: February 14, 2013, 07:19:58 AM »
NO,
In regards to the machine shop's treatment of your broken stud.  They should not have left you with burrs.  The burrs could very well be a product of the removal process, but so should have been the removal of those burrs in a way that didn't compromise the matting surfaces.  Even if the shop you went to didn't know jack about engines, ANY machine shop SHOULD know about mating surfaces and that burrs are unacceptable.
Careful with that dremel, it's very easy to create depressions in aluminum.  I'm not an expert in engine mating surfaces so I won't comment further on how to proceed, but if you do a specific search or posted specifically, you'd get an answer I'm sure.
Good work, and good luck!
Yes I realize it's not how it should have been done. I'm not happy with their work, their price, or how long they took to do the work. It's not worth fighting them though. They just won't be getting my business in the future.
I used a little sand paper disc on the dremel that is flexible. I thought this would be best since the flexible nature of it would tend to only take the high spots down. You'll note I just touched them up and removed the high spots and left the little impressions. Fortunately this is the base gasket area and not the head gasket surface. I will probably just put a touch of sealer on that area before I put the cylinders back on. I think it will be OK.
I think it was mostly the high heat of the drying cycle in the dishwasher that affected my parts. I wanted the high heat though to cure the paint somewhat. (I tried using the oven with some other parts and the smells got me in a lot of trouble ... ha).
IW
Offline Garystratos201
  • I have never been a
« Reply #278 on: February 14, 2013, 07:44:46 AM »
Nice work  !!! I going to attempt to replace the foam in my seat myself I got some high density foam from a local upholstery shop for $3.00. Price was right..........Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline iron_worker
« Reply #279 on: February 14, 2013, 01:02:44 PM »
The foam on mine is in fine shape and the leather is ok too. It's everything else. I'm leaning towards just reaching deep into the pockets and gettin a new one. ha
I dont' have to really decide for another month or so. It's not like the seat really holds up the build. lol
IW
Offline lostinthe202
  • Quality testing Elite 80's since 1978!
« Reply #280 on: February 14, 2013, 05:47:27 PM »
NO,
IW
Sorry, it was late and after re-reading your post, I realized I missed that you were being sarcastic!  Yeah, looks like you did a good job fixing their mistake.
'72 CB500
Offline iron_worker
« Reply #281 on: February 16, 2013, 06:17:35 PM »
The weekend started off well: Cycle X parts showed up! Or at least some of them... Apparently they shipped 2 boxes but for some reason shipped one Fedex and one USPS... I don't get it but oh well.
Sweeeeet. Everything was packaged well...
In this! All packaged up in the crate I sent to them plus extra padding.
Nicely refreshed head. It was glass beaded, surfaced top and bottom, new guides pressed in and reamed, superflow valves installed w/valve job, new springs, and titanium retainers.
Lookin fresh!
Doesn't get much cleaner than that.
Cylinders also glass beaded and surfaced, bored +.25mm, and honed to finish size.
Lovely.
Balanced crank. They said it was out 6g and now it bang on. Balanced out as nicely as their drag bike he told me. Cool!
I also had them pull the ball bearing plugs out and clean the oil passages then retap the hole for NPT plugs.
I can read the letters on my crank now. Doesn't really matter at this point but just neat to see.
Sent my rods back all packaged up. He didn't do anything with them but I thought he might need them to balance the crank... guess not!
My degree wheel and some sealant.
Super gasket kit.
All the seals and o-rings.
Looks like he stamped my initials in the cylinders and heat. Pretty neat.
Put a helicoil in near the cam chain tensioner hole.
A view of the new guides lookin purdy.
Then I spent several hours going over everything with varsol, a rag, and a screwdriver. Then I painstakingly taped everything. This took way longer than I imagined... as usual.
You'll note I'm repainting the MC and a couple covers. I wasn't happy with their finish the first time.
Ran to the hardware store and picked up an extra paint just in case. Figured I wouldn't need it but then when I got back I noticed that one of the ones I had already was the wrong color! I do have a little bit of luck! lol
Hardware store spoils... I treated myself to the T handle allen wrenches since I've got the allen head bolt kit on the way.
I re-murderized the room one lats time (hopefully).
After the first coat.
Last coat and it's looking better than it did the first time. Woot!
Hopefully I got all the nooks and crannies... there are a lot of them!
Well I was hoping I would get all my Cycle X stuff before this weekend and was hoping to get my DSS stuff but I guess not. Oh well, I'm pretty certain I'll have it before next weekend.  have a few things I can keep on working away at in the mean time anyway.
IW
« Reply #282 on: February 16, 2013, 07:18:10 PM »
The Cycle X work looks fantastic.  Good luck with the engine paint.  It's looking great so far.
« Reply #283 on: February 16, 2013, 07:36:38 PM »
whats he building in there?
What's he building in there?
Offline SF
  • I burn gas very well
« Reply #284 on: February 16, 2013, 08:50:01 PM »
just read the hole thread, im impressed with your attention to detail and organization. great job.  i will never complain about my single car garage again
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #285 on: February 16, 2013, 10:38:20 PM »
Mother-f-ing irritating video.  Hopefully none of my neighbors share that mentality.
« Reply #286 on: February 16, 2013, 10:41:19 PM »
ha!ha! i couldnt help myself.
Offline Viktor.J
  • Breaking in the forum
« Reply #287 on: February 17, 2013, 02:14:10 AM »
those parts looks nice IW. Did you just add a clear coat layer on the stator cover or color layer ? Looks really good !
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline iron_worker
« Reply #288 on: February 17, 2013, 10:35:27 AM »
lol WTF Dave?
I didn't clear any of my parts. I've only heard bad things about clear slowly yellowing with heat. We'll see how the Duplicolor holds up without it. I just sanded with 320 and painted again on the MC and stator cover. There were some imperfections that I wasn't happen with ... however upon sanding I discovered they were actually casting defects and not paint defects. ha
I threw the cylinders, head, and valve cover on the cases this morning (just set them on).... it's gonna look good! Pics to come later perhaps.
IW
Offline CBJoe
« Reply #289 on: February 17, 2013, 12:27:38 PM »
Not Tom Waits fans apparently ;)
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
Offline iron_worker
« Reply #290 on: February 17, 2013, 05:40:12 PM »
Chipped away at some things today. Seems like I kind of got sidetracked and just did little things but they needed to be done nonetheless.
Started off by pulling all the plastic down again and cleaning everything. I hate throwing all that plastic out. Such a waste...
Finally found the right hardware to install my new horn. Small job... but needed doing. lol
I went crazy with the anti-seize and basically took out all the bolts I've installed up until this point and add anti-seize. Only really needed these tools. Beauty of a Honda.
Got the rear fender and new grab bar/tail lights on. Really started look more like a bike with this on. note the convenient flash to block out my plate number. lol Not really sure why this is a big deal anyway?
My freshly painted head and cylinders. Matches up nicely with the valve cover that was painted a couple weeks ago so that's a good sign.
Then I tackled some electrical work. Replacing a #$%*ty plug end, adding some bullet connectors that got cut off, etc.
Fresh male bullet connectors for my front signals.
I crimped and soldered them.
Replaced this crapped plug off of my ignition switch. Just making note of the color pattern.
A tip I figured out... these little spade connectors (I think that's what they are called?) work perfect for pushing the little tang down so you can pop the connectors out.
Looks like this.
Ignition switch with a fresh plug.
Threw on my new brake and clutch handle. Although I broke my clutch switch in the process.... can I just "jump" the clutch switch so the safety starter unit thinks it is depressed?
So took a few hours to get this stuff down but didn't look like much progress when I was done. Oh well.
IW
Offline cheftuskey121
  • Super Newbie
« Reply #291 on: February 17, 2013, 06:33:32 PM »
good work iron, keep it up. I am still alive, got all parts primed except my tank, working on bondo'ing a few dents, hoping to prime tonight. I am just too lazy to post an update yet. its such a royal pain on this slow computer. transfer files, upload files, embed files. can't wait to see more, the engine is looking good!
Offline iron_worker
« Reply #292 on: February 17, 2013, 09:48:16 PM »
Wanna do my paint work too?  Lol
IW
  • Super Newbie
« Reply #293 on: February 17, 2013, 09:53:02 PM »
I actually enjoy doing paintwork. I think shipping would murder the benefits of having me do it though, best find someone local ;)
Offline CROMOLY
« Reply #294 on: February 18, 2013, 06:11:32 AM »
Hé,
Looks like your getting things done well, keep it up, looking good.
Still wondering how you will manage to take the bike out of your apartment??
Crom.
Offline Scotty J
« Reply #295 on: February 18, 2013, 06:34:57 AM »
MReick's million-dollar CB is going to have some competition once you're done!  Did the grab bar bolt right up, or did it need some encouragement?
1972 Honda CB750 Four
2010 BMW R1200 GSA
Offline iron_worker
« Reply #296 on: February 18, 2013, 10:04:19 AM »
The plan for taking it out of the apart is to pull the entire front end off via the stem nut. That should drop a lot of weight. I will also remove the rear wheel w/ swingarm and shocks as one piece and probably pull the rear fender off too just to save some length. The exhaust will obviously be off too.
So will have 3 major sections to carry down: engine/frame, complete front-end, and rear wheel & swingarm... then some misc parts to put on like exhaust, battery, seat, etc etc etc. Engine and frame will be the heaviest/most awkward but I think that's probably 200-250lb of the bike so it should be manageable with 2 or 3 guys.
I'm also considering strapping the frame to a 2x4 frame of sorts and then we could just "skid" it down the stairs... or ski it. lol
IW
Offline Roach Carver
« Reply #297 on: February 18, 2013, 10:50:39 AM »
What stage is the headwork?  what I mean is did they do any porting on just clean and put in new larger valves. It looks like they left quite a bit of material around the guides. Great build btw!
Offline iron_worker
« Reply #298 on: February 18, 2013, 01:36:19 PM »
No porting. Just superflow valves (stock size). I'm just going with a mild cam so I think it will be a nice fit. Mostly stock with a bit of pep.
IW
« Reply #299 on: February 18, 2013, 02:22:21 PM »
IW
Thanks
