Author Topic: CB750 seals/bearings and piston  (Read 1090 times)
Offline chris
« on: October 31, 2012, 04:21:22 AM »
Hi Could someone tell me the best place to buy bearings/seals and gaskets for a rebuild thanks Chris
Offline madScientist
Re: CB750 seals/bearings and piston
« Reply #1 on: October 31, 2012, 05:33:47 AM »
I'm probably ordering mine through dynoman:
http://www.dynoman.net/bikepages/sohc/index.html
For an F2
Main bearings $140
Rod bearings $100
Oil seal kit $35
Vesrah full gasket set $90
Not cheap...
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline iron_worker
« Reply #2 on: October 31, 2012, 08:24:06 AM »
Cycle Xchange is another good place to check out.
IW
« Reply #3 on: October 31, 2012, 08:29:49 AM »
Not to add more expense to your project but you might want to consider changing the primary and cam chains while your at it. If you've gone so far as to split the case might as well try to make it as reliable as possible...just a thought.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
