The SOHC/4 World Tour is in under way.
Details. The arrow apparently points backwards.
Hondaman:>>...make sure the axle caps (on the ends of the forks) are installed properly. They should be flat and even at the back side with a (parallel) gap on the front side. Tighten the rear sides first, then the fronts. The caps are DIRECTIONAL: they have a HI and LOW side to them. The gap side must be in front.<<< Is that specific to 1969 only?I know I've seen it somewhere and did work on some real early ones, carb sync is a real PITA with 4 cables
I took apart those F2 forks and it was indeed PO who tightened those clamps down to 0 gap. Luckily nothing was furked up.
