Author Topic: Baffling methods...which to use for what purpose?  (Read 398 times)
Offline RFogelsong
« on: November 07, 2012, 04:54:54 PM »
So I've seen a number of different ways to baffle pipes, fiberglass/steel wool, mechanically (make the gas turn corners and such inside the pipe), those perforated metal inserts...
Which is "best", or maybe, does each type give a distinct sound or why isn't everyone using the same method?
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Re: Baffling methods...which to use for what purpose?
« Reply #1 on: November 07, 2012, 09:16:09 PM »
It's usually a packaging problem. A baffled system works well but it needs a large area to fit in to be quiet. Many muffler cases are tapered, that's a concern too. I prefer a large dia. can with a glasspack insert.
