Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Did you remember to replace the spacer between the two bearings mate? Cheers, Terry.
you can miscue the speedo drive gear jigger,by just a little,you should be able to way over tighten the axle nut and not affect its turning friction,,i just do them up real tight,back off the nut and square the speedo drive back again.
Thanks to all for your suggestions and support. I'm such a dumbarse!! I had in fact not seated the speedometer drive correctly. The good news I didn't force anything and damage the drive. Hopefully this exercise will help someone else down the line.Moral of the story: work slowly and carefully, checking your work along the way and if you are true to yourself and have some skills you should trust your instincts.I'm glad to be a part of such a great group. Sometimes the moral support is all you need to get past a bump in the road.
