Author Topic: Paint that matches zinc plating  (Read 1900 times)
Offline markb
  • When I finish my current project I might be a
« on: November 08, 2012, 10:32:27 AM »
I have some early sandcast oil lines (rubber hoses) that are usable but the metal ferrules are a little rusty and need some restoring.  I’m thinking the easiest solution would be to soda blast the aluminum fittings and steel ferrules and then mask and paint the ferrules.  Any recommendations on paint that will look like zinc plating?
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline mafd2
Offline markb
Re: Paint that matches zinc plating
« Reply #2 on: November 08, 2012, 12:02:49 PM »
That was to easy.  :D I don't know why I didn't think of Eastwood.  Thanks.
Offline brewsky
« Reply #3 on: November 08, 2012, 12:36:03 PM »
You could also do diy zinc plating
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline markb
« Reply #4 on: November 08, 2012, 12:45:40 PM »
 ??? I'm not sure what that does for me.  The ferrules are assembled on the hoses between the rubber and the aluminum.  It seems that either way they would go in a plating tank which doesn't seem like a good idea to me.
Offline brewsky
« Reply #5 on: November 08, 2012, 01:11:24 PM »
The plating solution is simply sugar, vinegar, and epsom salts........not sure if it would be that harmful to rubber or not.
Maybe someone with a more chemical background would know??
It would only have to be in the solution a few minutes.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline markb
« Reply #6 on: November 08, 2012, 01:25:52 PM »
I don't know much about plating but I thought zinc plating was an electroplating process using an electric current and a zinc anode.
Offline brewsky
« Reply #7 on: November 08, 2012, 01:43:39 PM »
See reply #15 in this thread....
http://forums.sohc4.net/index.php?topic=111604.0
It's really simple ......and habit forming too.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline markb
« Reply #8 on: November 08, 2012, 01:50:42 PM »
Wow brewsky, thanks for the link.  Very interesting reading.  I may have to experiment with this.  Anyone know what that process would do to rubber or aluminum?
Offline brewsky
« Reply #9 on: November 09, 2012, 03:27:01 AM »
I definitely would experiment before trying a rare part.
I would keep the rubber away from "the works" cleaner as it is acid, but other cleaners should be fine.
Not tried aluminum, but the zinc will not plate over chrome, it just brushes off in flakes. (This actually comes in handy when trying to repair a small rusty spot on a chrome piece). Aluminum may be similar?
The actual plating solution seems pretty benign to me, and putting my hands in it has had no ill effects, so I doubt it would harm rubber with the limited exposure time. I have seen some attached brake line ends done on you tube, but again, maybe someone else could chime in who knows?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline lone*X
« Reply #10 on: November 09, 2012, 10:09:10 AM »
This might be a way to recondition old spokes.  I have a full set with minor surface rust but no pitting that I might give this a try on.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
