Author Topic: Tail light quit working - CB750F1  (Read 1993 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: November 08, 2012, 01:17:12 PM »
My buddy noticed last weekend that my tail light is out. Brake light works, but running light does not. Replaced the bulb - still nothing. Likely a connection came undone?
Offline MoMo
  • Ride like you're invisible
Re: Tail light quit working - CB750F1
« Reply #1 on: November 08, 2012, 01:53:35 PM »
Measure voltage at the brown wire.  There are connections under the housing and another under the seat.  Also, the ignition switch could be defective as the brown wire feeds from there.  Not sure if your model has a fuse for the tailight...Larry
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #2 on: November 08, 2012, 01:56:29 PM »
Thanks - this at least gives me a place to start from :)
Offline MoMo
« Reply #3 on: November 08, 2012, 01:58:54 PM »
You are welcome.  Most common problem I see is the connection under the seat coming apart...Larry
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #4 on: November 08, 2012, 04:16:46 PM »
So I can unplug the brown wire @ the tail light - brake light still works, tail light doesn't work. Cleaned the connector and reattached - still doesn't work. What do I check next?
Offline MoMo
« Reply #5 on: November 08, 2012, 04:43:41 PM »
You need to check to make sure you have voltage at that wire.  If you do not have a multimeter(working on vintage Hondas having one is mandatory) go to Harbor Freight and buy an inexpensive one-should be less than $10...Larry
Offline ChuckG750f1
  • Not your average, everyday, run-of-the-mill
« Reply #6 on: November 08, 2012, 05:01:55 PM »
One of the 7A fuses is for the taillight!  If it's not the fuse or a connector, it may be bad contacts in the ignition switch (that's how the 12V gets to the fuse).
Life is hard; it's harder if you're stupid.
- John Wayne
1976 CB750 f1
1995 HD Softail Custom
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #7 on: November 08, 2012, 05:22:31 PM »
Now there's your problem:
Guess this will have to do for now. Fix it right this weekend :)
Offline MoMo
« Reply #8 on: November 08, 2012, 06:39:35 PM »
Good work, and there are waterproof connectors  available like your temporary fix...Larry
