Author Topic: 1975 CB750 K5 SPYDER  (Read 63404 times)
Re: 1975 CB750 K5 SPYDER - Moving on FORWARD
« Reply #200 on: January 01, 2014, 12:44:38 PM »
Ordered it, thx.  It ships from PS very close to my house...
Offline goldarrow
  • one day, i'll be an
Re: 1975 CB750 K5 SPYDER - Splitting Cases
« Reply #201 on: January 01, 2014, 02:19:09 PM »
Spent half a day stripping down the bike, most of time really was cleaning up oil in the floor.  Must have spilled at least a qt. of oil while draining.
CB550 K0
Offline goldarrow
« Reply #202 on: January 01, 2014, 03:34:33 PM »
I swear first time doing it was much easier.  But engine is out finally.  Now what?
CB550 K0
Offline goldarrow
« Reply #203 on: January 01, 2014, 06:05:14 PM »
Got the cases split
Looking for the obvious, but where?
CB550 K0
Offline goldarrow
« Reply #204 on: January 01, 2014, 07:11:06 PM »
Is this what causes my 2nd jerks a lot?
CB550 K0
« Reply #205 on: January 01, 2014, 07:32:15 PM »
That certainly is an issue. Doesnt seemed to be spaced properly?
Offline MoMo
  • Ride like you're invisible
« Reply #206 on: January 02, 2014, 06:32:16 AM »
That and the gears it slides into definitely.  Problem usually caused by rider abuse-as has been mentioned earlier the bottom end is practically bullet proof unless abused...Larry
Offline iron_worker
« Reply #207 on: January 02, 2014, 06:45:49 AM »
I would not expect to see any where there at all? Usually all the wear is on the end of the "forks". Makes me wonder if your shift forks were installed backwards or some such thing...
IW
Offline KrautKoffin
« Reply #208 on: January 02, 2014, 11:33:40 AM »
Awesome build! What did you end up doing with those wheels and body kit?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline goldarrow
« Reply #209 on: January 02, 2014, 06:01:51 PM »
Found left shift fork in parts bin, wonderful condition, got it cleaned up and oiled.   Looked into the gear drum more closely, there is a good amount of wear on the slot where that damaged fork pin sits.  Will have to dig in my parts bin again. If not found, I might have to hit Stevo up for the drum
CB550 K0
Offline goldarrow
« Reply #210 on: January 02, 2014, 06:02:39 PM »
They have been sitting on the shelves.  No idea what I'm gonna do with them.
CB550 K0
Offline goldarrow
« Reply #211 on: January 02, 2014, 06:04:08 PM »
Worn shift drum, caused the shift fork slipping??? At least that what I see in it at the moment
CB550 K0
« Reply #212 on: January 02, 2014, 06:05:44 PM »
Pic?   I should have one.....
Offline goldarrow
« Reply #213 on: January 03, 2014, 04:40:10 PM »
Not sure how we'll you could see from the pic, but there is a worn area with my screwdriver pointing at it
Now my question is, how do you remove the drum, before I damage the case
CB550 K0
Offline goldarrow
« Reply #214 on: January 03, 2014, 05:16:27 PM »
Got the shift drum out, that was too easy, just had to remove the neutral switch at the bottom
And here's a better shot of the worn drum
Found a shift drum in my parts bin, just have to clean it up and oil it
CB550 K0
Offline MoMo
« Reply #215 on: January 03, 2014, 06:13:41 PM »
What is the condition of the gears that that shift fork actuates?  I can visualize the dogs being rounded off...Larry
Offline goldarrow
« Reply #216 on: January 03, 2014, 08:10:55 PM »
Here's the gear the bad L fork sits on
dogs on different gear
2 shiny wear marks on another gear?
Thoughts, recommendations,  suggestions, anything helps.
CB550 K0
« Reply #217 on: January 03, 2014, 09:03:19 PM »
Sorry, Gold, I just am having a hard time seeing the issue in the pics [and yes, my eyes are good!]
Can you put the trans back in with a good shift drum and fork and try to shift it and see how it looks?
Offline MoMo
« Reply #218 on: January 03, 2014, 09:39:59 PM »
Gotta agree with Steve, though  the inner part of the lower dog in the first photo does appear to be a tad rounded but that could be either a refection or something close to normal wear and tear.  I am surprised there isn't damage...Larry
Offline goldarrow
« Reply #219 on: January 04, 2014, 05:45:41 PM »
Case half is back on now, just needed few small hit with rubber mallet.  All is too easy, too good to be true? Used small amount of hondabond around the mating surface, then tight up the bolts.
My concerns are two things as I couldn't see how the center fork went on to the gear slot, and chain roller. Any pointer?
CB550 K0
Offline MoMo
« Reply #220 on: January 04, 2014, 05:53:46 PM »
You should be able to shift through the gears to ascertain it is together correctly, and it is hard to put the cases together wrong...larry
Offline goldarrow
« Reply #221 on: January 08, 2014, 11:25:02 AM »
That's a relief.
Got the engine all buttoned up, cleaned, and degreased, will need some touch up paint before going back in the frame
CB550 K0
« Reply #222 on: January 08, 2014, 03:28:30 PM »
That's a relief.
Good news. And the test shifting seems fine?
Offline goldarrow
« Reply #223 on: January 08, 2014, 11:05:30 PM »
Test shifting by hand seems fine, shifts and locks into gears while turning the front sprocket.  May be few times felt like false neutral but that could be because using my weak  hand to turn sprocket???
Or may be I should have my mind set for a 3rd tear down...hmm....
CB550 K0
Offline MoMo
« Reply #224 on: January 09, 2014, 02:03:34 AM »
That does seem normal.   Good luck with it...Larry
