Author Topic: 1975 CB750 K5 SPYDER  (Read 61844 times)
Re: 1975 CB750 K5 SPYDER - Splitting Cases
« Reply #225 on: January 09, 2014, 05:40:56 AM »
Test shifting by hand seems fine, shifts and locks into gears while turning the front sprocket.  May be few times felt like false neutral but that could be because using my weak  hand to turn sprocket???
Or may be I should have my mind set for a 3rd tear down...hmm....
That does seem normal.   Good luck with it..
+1.  When do you plan to reinstall the motor?
Offline goldarrow
  • one day, i'll be an
« Reply #226 on: January 09, 2014, 05:51:20 PM »
motor is ready to go back on the frame.  hopefully i can get it back up running again this weekend, just can't wait!  the HM300 sounded so good the last 50 miles :)
CB550 K0
Offline goldarrow
« Reply #227 on: January 10, 2014, 06:29:22 PM »
Lifting frame up to get motor out was a chore, especially when front and rear ends still attached, and doing it one man show.
So, doing it differently this time.  Got the bike frame lifted high suspending on the sawhorse, then lifted the engine up into the frame.  Much easier
CB550 K0
« Reply #228 on: January 10, 2014, 07:11:25 PM »
Wow.....haven't seen it done that way before!
Offline Jerilee
« Reply #229 on: January 12, 2014, 12:15:42 PM »
I wish *I* had thought of that! Good job!  ;D
Jeri~
My F2 build http://forums.sohc4.net/index.php?topic=126314.0
77/78 cool 2 member
Offline goldarrow
« Reply #230 on: January 13, 2014, 03:19:56 PM »
Got the bike all assembled, started right up like nothing ever happened, but then I remembered that I only have 2 quarts of oil in the motor, so didn't take it out for a test ride.
Also installed rear blinkers, will take it out for test ride when I get my oil, hopefully no more issue with the tranny.  then transfer title into my name, register and insurance, and should be back on the road!
CB550 K0
« Reply #231 on: January 13, 2014, 03:24:50 PM »
Good news!  PM me your address and I'll send you that points cover....
Offline goldarrow
« Reply #232 on: January 13, 2014, 03:38:06 PM »
Thanks stevo.  Just sent you text
CB550 K0
Offline goldarrow
« Reply #233 on: January 17, 2014, 05:11:43 PM »
Hey Stev-o, you crack me up!
The points cover looks million times better than what I got! And thanks for the key chain.  Appreciated :)
CB550 K0
Offline goldarrow
« Reply #234 on: January 17, 2014, 05:15:22 PM »
Here's my beat up points cover
New batch of oil should be here tomorrow, I'm excited!
CB550 K0
« Reply #235 on: January 17, 2014, 05:41:31 PM »
Nice wall art ya got there Gold Dude!   Strip and polish the new one and you should be good to go...
Offline goldarrow
« Reply #236 on: January 19, 2014, 11:57:31 AM »
Just put another 40 miles on the bike.  Beautiful ride this morning.  Case closed with no more shifting and 2nd gear issues!
CB550 K0
« Reply #237 on: January 19, 2014, 11:59:01 AM »
Good news and great job!   And you were doubting yourself?
Still need the tool tray? PM sent....
Offline goldarrow
« Reply #238 on: January 19, 2014, 12:20:00 PM »
Always a learning curve :)
Yes, I can use tool tray so I can have some tools under the seat.  Was riding this morning, and bike drop cyl 2 and 3, turned out to be slow jets fell to bottom of bowls.  I was at swap meet parking lot while checking this and an older guy on Harley let me borrowed his leatherman tool.  That was a good experience too, lol
« Last Edit: January 19, 2014, 12:24:38 PM by goldarrow »
CB550 K0
Offline goldarrow
« Reply #239 on: January 31, 2014, 04:50:53 PM »
Courtesy of Stevo, got this rusty tool tray in the mail last week.  It cleaned up nice.
Then few coats of rust reformer paint all looks good.  Scavenged tools out of my tool carts
All good.
CB550 K0
« Reply #240 on: January 31, 2014, 05:48:00 PM »
Glad you got it, Gold, looks good.  Except the bolts aren't in all the way?
Offline goldarrow
« Reply #241 on: January 31, 2014, 06:19:00 PM »
Correct bolts are hard to find! Fender bolts will do for now, lol
CB550 K0
Offline edwardmorris
  • Youngish
Offline goldarrow
« Reply #243 on: June 04, 2014, 08:04:50 PM »
Scored this.
Not the price I wanted to pay, but exactly the seat I wanted.  After all, period correct in fairly great shape for its age.  Mounted it on with plunger.  Perfect fit.
« Last Edit: June 04, 2014, 08:07:47 PM by goldarrow »
CB550 K0
« Reply #244 on: June 04, 2014, 08:09:32 PM »
Good buy, I like those too.
Hey....your workshop there is looking a little crowded.  Maybe you should sell some MGP pipes to make some room?!
Offline goldarrow
« Reply #245 on: June 04, 2014, 08:41:06 PM »
Not yet.  Will let you know.
I have at least 2 oil tanks for 750k bikes if you need
CB550 K0
« Reply #246 on: June 05, 2014, 07:07:40 AM »
Thanks but I think I have three
Offline mcswny
« Reply #247 on: February 28, 2015, 08:29:42 PM »
Hey Goldarrow, I know you haven't poster here in awhile. But I'm helping my buddy fix his second gear issue and his shifter fork looks IDENTICAL to yours.
Was wondering if you ended up swapped the gear that had the rounded dog? Or the shift drum? Or was it just the Shifter Fork?
Thanks!
Tim
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline goldarrow
« Reply #248 on: February 28, 2015, 08:48:27 PM »
Thanks!
Tim
I had to replace both the shifter forks and shifter drum as the drum showed wear along the grooves.
If I recall correctly, Remove the neutral switch on the bottom of the case, the drum should slide right out.
CB550 K0
Offline mcswny
« Reply #249 on: February 28, 2015, 08:53:48 PM »
Thanks so much for the quick reply. I'll check in the morning!
1972 CB750 K2
1975 XL250
198 XR80
