Author Topic: CB550 Big bore planning  (Read 6947 times)
Offline akabek
« on: November 10, 2012, 04:44:17 PM »
I currently have a CB550 with a 650cam, CR29, MAC 4-1 header, cone engineering reverse muffler and electronic ignition, coils and wires.  My head gasket is leaking so it is time to tear into the motor.  My plan is to go for a big bore 61mm Dynoman piston kit, port, polish and valve job.  Is it worth while going for a 3 angle valve job?  I have a complete gasket set but what else should be replaced while I have it all apart?  I have read it is good practice to replace the cylinder studs.  Should I upgrade the clutch plates and springs?
« Last Edit: November 10, 2012, 04:45:54 PM by akabek »
Offline turboguzzi
Re: CB550 Big bore planning
« Reply #1 on: November 11, 2012, 03:18:02 AM »
kevin camron says in his book that he's seen, bikes with 3-angle, no angle and what-have-you valve seats, all in the winners cycle, so until i see (one day....) flow testing of a 500/550 head with 3 angle being better, i'd say just do normal maintenance/ basic port cleaning.
Theres no evidence that polished ports flow better either, even the opposite, i like to leave them rather coarse. no doubt polished ports look cool in pictures, if the air particles like it is another matter
At this point you'll ave to tell us your info sources :) why change studs? where did you read that? steel is not a material that has a fatigue limit...
would wait with the clutch until you see that its slips under power, the stock one is pretty good, all i often do is add washers under the springs to preload it more by 1-2mm
and would go with mrieck's mls head gasket....
Offline akabek
« Reply #2 on: November 11, 2012, 07:41:54 AM »
[/quote]
I read on this forum references to the bolts stretching but than some have reused the bolts with no issues.
I thought Mrieck's MLS head gasket is from Dynoman.  When I place my order for the Dynoman 61mm bore kit I was going to ask them for the MLS gasket.
Offline turboguzzi
« Reply #3 on: November 11, 2012, 08:04:39 AM »
in order to get studs to stretch, you'd need to overtorque them and go into the plastic deformation range....  IMHO at least but maybe it just never happened to me
interesting, what do other engine meisters here say? do/can studs stretch (i.e. unreversible plastic deformation) under normal loads - meaning torqued within their elastic range?
« Last Edit: November 11, 2012, 08:08:07 AM by turboguzzi »
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: November 11, 2012, 11:34:32 AM »
If memory serves me, the Dynoman pistons come with a MLS head gasket.
I'm going the HD stud route too. Might not be necessary, but I've already pulled the factory studs.
Offline akabek
« Reply #5 on: November 11, 2012, 02:03:40 PM »
I figure I should show a pic of my work in progress.
« Last Edit: November 11, 2012, 02:21:08 PM by akabek »
Offline Johnnie
« Reply #6 on: November 19, 2012, 09:23:14 AM »
Very nice!
What rearsets are those?
Offline Sara
  • Be different, be yourself
« Reply #7 on: November 19, 2012, 10:33:49 AM »
I think they are from Tardozzi, have the same.
Sara
Offline akabek
« Reply #8 on: November 19, 2012, 12:38:19 PM »
Sara is correct
Offline turboguzzi
« Reply #9 on: November 19, 2012, 12:55:07 PM »
a cafe job that has some proper performance mods and no heat wrap on the pipes?
WOW, kudos you man.... :)
Offline akabek
« Reply #10 on: November 19, 2012, 02:53:48 PM »
I know there are apparent benefits to wrapping the pipes but I am going for a clean look and a sleeper.  ;D
Offline singedebile
« Reply #11 on: November 22, 2012, 02:58:35 PM »
my pet peeve exactly, you see these 5-10k builds with NOTHING done for performance,... stock brakes and engine.
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline akabek
« Reply #12 on: November 22, 2012, 04:10:52 PM »
I am not sure if you are referencing my build with your comment but since when were there rules you have to follow?  Granted my brakes are stock, they have been upgraded to dual disc.  My motor will have a higher displacement, 650 cam, porting and Keihin CR29 carbs with stacks.  The suspension is upgraded with Ikon rear shocks and Race Tech emulators with new springs.  I understand the benefits of wrapping the header but I prefer a cleaner look for my build.  At the end of the day it is personal preference which is what makes every bike on this forum unique.  This is a 40 year old street bike
Offline singedebile
« Reply #13 on: November 23, 2012, 01:08:25 PM »
I was complimenting your bike, ..i was saying it is refreshing to see someone focus on more then just the way the bike looks and to me that is a real cafe racer.
Offline akabek
« Reply #14 on: November 23, 2012, 02:23:23 PM »
My apologies and thank you for the compliment.  I am aiming for some performance but a clean/vintage look...not show room.
Offline turboguzzi
« Reply #15 on: November 24, 2012, 01:16:58 AM »
it was a compliment from me too. the amount of "all pose no go" sohc's out there is just amazing, your's is pretty remarkable in that sense.
Offline akabek
« Reply #16 on: November 24, 2012, 05:50:46 AM »
Thanks again.  I guess that is what makes bike builds so interesting.  Some want show bike quality, some are looking for performance and others want both.   Originally I had no intentions for a big bore, cam and 4-1 exhaust but after the build I wanted more street performance.  So far I am impressed with the bike although I have never ridden a stock CB550.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #17 on: November 24, 2012, 11:48:04 AM »
It's an addiction.
Better get used to it.  ;D
« Reply #18 on: November 24, 2012, 01:49:35 PM »
It's an addiction.
[/quote]
Hah, +1 to that!
Offline Kemp
« Reply #19 on: November 28, 2012, 09:35:29 AM »
Check out Funjimmy's post with the CR26's. That might be of help with the issues you've been having with your CR29's. Again, you really can't beat a big bore for performance. Even with your mild CB650 cam, the dynoman 10.5 591cc kit will make your bike rock!! A side benefit is that the 650 cam allows you to keep the torque that the big bore allows. I noticed quite a difference btw 650cam and Web B grind on my 591. The web gave more HP but really hurt the low down torque and mid range acceleration whereas the 650 cam would straighten your arms when you got hard on it at 6000 rpm. The Web would hit hard at 7500 but torque was gone and you needed to ride it like a road race engine, on the boil from 8000 to 10,000 to keep the acceleration strong and momentum up. I road raced a lot of different TZ models in a past life and the web cam reminded me of those 2 stroke machines, peaky!! I think the 650 cam, as it has just a bit more duration than a stock 550's, is a really effective street cam for everyday use.
Offline akabek
« Reply #20 on: November 28, 2012, 05:15:44 PM »
Hi Kemp, I spoke with Jimmy already.  We had similar stories with our CR carbs although mine is the CR29.  I am sticking with my 650 cam as I prefer the low end torque for street use.  My jugs and head are currrent at the shop so I should be all set for next summer.
Offline akabek
« Reply #21 on: March 13, 2013, 01:32:48 PM »
I recently rebuilt my motor with a big bore kit but I want to hold off on starting it up for another month when the weather is warmer.  Is there anything I should do to get the internals lubed before I put gas in and start it up for the first time?  I did apply oil to the rings and cylinders during the installation but the motor will have been sitting for approximately 6 weeks before I start it for the first time.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #22 on: March 13, 2013, 03:19:43 PM »
You shouldn't have any issues as is.
Let us know how it goes.
Cheers
FJ
« Reply #23 on: March 13, 2013, 04:10:00 PM »
Jimmy has a hell of a kit too. His bike is going to be fantastic and fast.
Offline akabek
« Reply #24 on: March 13, 2013, 04:20:56 PM »
I am looking forward to see how it all comes together: 592cc (10.5:1), Keihin CR29, ported head with 3 way valve grind and CB650 cam.  It should make the bike nice and peppy...maybe I will take it to the track this summer and see how she goes.
