Author Topic: My first bike: '78 CB750k  (Read 54193 times)
fendersrule
Re: My first bike: '78 CB750k
« Reply #150 on: January 21, 2013, 02:51:37 PM »
Bingo!
Offline toytuff
  • "watching the pinheads"
« Reply #151 on: January 21, 2013, 02:57:14 PM »
Bingo!
PM your address. I'll pay it forward.
tt
fendersrule
« Reply #152 on: January 21, 2013, 06:04:40 PM »
Thought I would like to share these, which just came in!
Just say "No" to blue! :)
Offline toytuff
« Reply #153 on: January 21, 2013, 07:13:39 PM »
I'm going to the PO tomorrow if you want that rubber bumper otherwise late in the week.
tt
fendersrule
« Reply #154 on: January 21, 2013, 07:23:47 PM »
You bet!  Did you get my PM?
Offline toytuff
« Reply #155 on: January 21, 2013, 08:22:03 PM »
Offline toytuff
« Reply #156 on: January 22, 2013, 01:14:47 PM »
In the mail today.
tt
fendersrule
« Reply #157 on: January 22, 2013, 03:19:35 PM »
You're the man. I owe you.
Offline toytuff
« Reply #158 on: January 22, 2013, 03:48:59 PM »
Stand behind Stev-o.  ;)
tt
« Reply #159 on: January 22, 2013, 04:04:21 PM »
Offline toytuff
fendersrule
« Reply #161 on: January 22, 2013, 07:40:57 PM »
About to order 2x emblems from an Australian reproduction place. It's about $100 total for both emblems including shipping. I know of no other place that has '78k side cover emblems. I'm going to give myself two weeks before placing the order, and then I've got to bite the bullet.
I'm also going to concurrently place an order on a Valley Green Metallic paint kit (with primer).
fendersrule
« Reply #162 on: January 27, 2013, 06:32:57 PM »
Well, that was hell, but it wasn't the worst thing I've had to do (getting a stuck rear-axle out takes the cake). After abandoning the "force and pry" tactic and resorting to the penny method, it created a much easier job. I don't know any other way that this could have gone on with a chain installed.
The job begins. I've been using this waterproof grease for about everything both for lubrication and to keep parts from rusting. You can find it at any Honda shop. Lubing the main stand axle is probably a really good idea.
Showing a good pry location for loading pennies in. Switch the spring around and repeat to the other side.  Unlike what the picture shows, start loading the inside of the spring first.
Take it over to a vice, and tighten the pennies in to give you more length in the spring.
When you're just a hair away, use some pliers and some force to complete the job. Damn.
Finished. Move the center stand down and remove the pennies using a rotating motion with pliers.
I bet she's really happy to have a restored pair of feet.
Taillight assembly restoration complete. I went with two stainless allen bolts. Thinking about putting two more on the bottom, but that may be overkill. I suppose if there's flapping and what not, then all four corners should be secure?
« Reply #163 on: January 27, 2013, 07:42:19 PM »
Two bolts is adequate for the plate unless it's super flimsy.
MUF?  Is that what you named the bike?!
Offline toytuff
« Reply #164 on: January 28, 2013, 06:22:31 AM »
Did I not say those center stands are a bit**!
Mine was terrible.
tt
« Reply #165 on: January 28, 2013, 06:28:09 AM »
Of the three SOHC Hondas in my garage right now, none came with a center stand.
Coincidence or explanation?!
fendersrule
« Reply #166 on: January 28, 2013, 11:02:17 PM »
MUF just happened to be the name on the plate. When I saw it, I should have requested MUF DVR.  8)
Just got confirmation on a place to get epoxy on the stuff. Lets just say that it's heated, downdraft, and state if the art. Can't say where though.
fendersrule
« Reply #167 on: January 29, 2013, 08:40:04 PM »
Pretty crappy reason for an update, but I have the exhaust back on.
And I also got all the electricals hooked back up to the battery tray (thanks ToyTuff for the grommet).
Now, paint. Stay tuned for some body work, my favorite part.
Offline toytuff
« Reply #168 on: January 30, 2013, 04:50:28 AM »
Looking very nice!
Did you replace the exhaust gaskets?
tt
fendersrule
« Reply #169 on: January 30, 2013, 06:48:10 AM »
You know, I'm not even sure the bike has gaskets. I certainly didn't see any. My dads '79 didn't have any either, so I assume they didn't exist.
Where's a good place to buy four of these without getting nailed with atrocious shipping? The bike has ran fine without them, but I suppose they are good to have.
EDIT: I'm sure I have exhaust gaskets as I've just read that they blend in with the head., and the bike would run obviously like crap without them. I don't plan on replacing these soon, but eventually. I would think that draining/replacing my fork fluid, rebuilding the master cylinder (not sure if this is needed or not), draining the brake fluid, replacing the rubber brake hoses with braided ones would be more important. Oh yea, and I need a new battery.
I haven't drained the engine oil yet, but I checked it when it arrived and it looked pretty good.
« Last Edit: January 30, 2013, 07:14:22 AM by fendersrule »
Offline toytuff
« Reply #170 on: January 30, 2013, 07:12:37 AM »
I always sit down and make a parts list. I don't have extras but yes, copper gaskets set between the pipe and the head.
GASKET, EX. PIPE
18291-MM5-860
tt
« Last Edit: January 30, 2013, 07:23:44 AM by toytuff »
fendersrule
« Reply #171 on: January 30, 2013, 07:21:40 AM »
I really don't want to pull a pipe back off again, but it would be very obvious if I didn't have gaskets, right?
Offline toytuff
« Reply #172 on: January 30, 2013, 07:25:42 AM »
If I told you how many times I did things twice well.....
Yup, pull them off if you are not sure. Do it right.
Why stop now as the bike is looking good. You'll sleep nights too!
tt
Offline iron_worker
« Reply #173 on: January 30, 2013, 08:00:06 AM »
Once the gaskets crush they expand and stick in the head. You probably have some flattened form a gasket stuck in there. New ones would be better though of course. The pre-crushed ones tend not to seal very well.
IW
« Reply #174 on: January 30, 2013, 08:03:25 AM »
I was going to ask too, but figured he did it. They are crush washers and most likely will leak if not changed.  I dug em out with a small screwdriver last week on my K5 before mounting the Kerker.
About $2 ea, your local dealer should stock them, no shipping then.
Or....
http://www.z1enterprises.com/ItemDetails.aspx?item=KL16-5977-1
