Author Topic: My first bike: '78 CB750k  (Read 61303 times)
Re: My first bike: '78 CB750k
« Reply #250 on: April 04, 2013, 07:26:47 PM »
Impatiently waiting....
fendersrule
« Reply #251 on: April 05, 2013, 04:39:21 PM »
No pictures of the tank yet..it's covered in masking paper because I'm flushing/soaking it.
Man, the paint and stripes turned out better than I expected. It screams vintage and classic at the same time. You guys will have to see the tank later this weekend when I'm finished with it.
Until then:
fendersrule
« Reply #252 on: April 05, 2013, 05:09:14 PM »
This is a better picture showing the Valley Green Metallic.
Tons better than Freedom Green Metallic, which has way too much blue in it IMO.
« Reply #253 on: April 05, 2013, 07:23:17 PM »
Hey Fenders - when I looked at the first pic I thought there were smudges on it. Then when looking at the others I figured out that that it was the reflection of the clouds!
Looks fantastic, love the color.
Offline Frankensteins Bride
« Reply #254 on: April 05, 2013, 07:35:05 PM »
That colour is freaking  beautiful!
Working on: 78 Cb750k
Waiting for arrival: 73 Cb750
Frankensteins Wolf
fendersrule
« Reply #255 on: April 05, 2013, 08:46:35 PM »
Uploaded with ImageShack.us
Uploaded with
fendersrule
« Reply #256 on: April 05, 2013, 08:47:19 PM »
Thanks guys for the comments. The vintage color and the stripes matched better than expected. It's truly a '78 that has all the retro options.
fendersrule
« Reply #257 on: April 06, 2013, 07:41:59 PM »
Took her out on the maiden voyage today after replacing the fuel line and fuel filter.
Drives like a champ!
« Reply #258 on: April 06, 2013, 07:52:43 PM »
Very nice, great job.  Now what??
fendersrule
« Reply #259 on: April 06, 2013, 07:58:56 PM »
Drive it to death and work on the CB450! That's undergoing a frame-off resto. Then the CB750 will undergo a frame-off.
Really nothing else to do on the CB750 except for painting the frame and rebuilding the engine in a couple years. That also includes rejetting the carbs (making sure they are stock) and putting the air box assembly back on it.
Bike runs, drives, and feels very nice. Best of all, it feels safe because I've done most everything.
« Reply #260 on: April 06, 2013, 08:10:52 PM »
Does yours start right up when cold? My K8 does now, but the starting procedure is differant than the K4. Since it has an accelarator pump, I pump it a couple times before cranking.
The K4 likes no throttle when cold cranking until it fires.
fendersrule
« Reply #261 on: April 15, 2013, 06:30:05 PM »
It's cold blooded like every other CB750. Gotta crank open the choke, and then just ease it off in 20 seconds. Once it starts it gets warmed up quick enough.
I haven't found that giving it throttle does any good for cold starts.
« Reply #262 on: April 16, 2013, 07:43:14 AM »
This is a misconception. My K2 is NOT cold blooded and start up with choke (10 secs) then is good to go (117 mains/40 pilot). Its all about the carbs. Had this experience with other pre-75 bikes. Perhaps the later model 750s are....
Anyway great job on the paint - looks really good! Now drive and enjoy!
cheers
Andy
Offline cheftuskey121
  • Super Newbie
« Reply #263 on: April 16, 2013, 07:55:38 AM »
Sweet baby Jesus that's pretty!
Offline iron_worker
« Reply #264 on: April 16, 2013, 08:03:28 AM »
Yes I believe the "cold blooded" myth came about because the pilot jets clog so easily on these bikes. After a thorough cleaning of my carbs the cold starting 100x better.
IW
fendersrule
« Reply #265 on: June 10, 2013, 08:51:08 PM »
Installed a much nicer oil tank. Has the label and all.
Installed the Airbox with a K&N filter. Good riddance pods!
Bike is finished aside from a vacuum hose and a quick checkup-tuneup from the local hog shop. Time to start on the CB450...wait, I already did. Frame is off for powder-coating. Wish those guys are as active as you guys on the HondaTwins forum!
« Last Edit: June 10, 2013, 08:53:19 PM by fendersrule »
« Reply #266 on: June 11, 2013, 05:58:51 AM »
I would not bring it to a "hog shop".   Why do you want to do that?
Offline deafcaferacer
  • "I'm sorry officer, I can't hear you!"
« Reply #267 on: June 11, 2013, 06:42:19 AM »
That bike is beautiful! I'm envious.
'73 CB750k engine, hubs, and a '76 tank, on 'a 78 frame. Go figure.
fendersrule
« Reply #268 on: June 11, 2013, 08:08:30 AM »
http://www.hogsandriceonline.com
I think it wouldn't be a bad idea to have an old geezer who loves these bikes fine tune the carbs using specialized equipment, and to double check everything else. For example, I've been driving around with my front axle lose for the past 300 miles.
« Reply #269 on: June 11, 2013, 02:53:47 PM »
What kind of "specialized equipment"?
fendersrule
« Reply #270 on: June 11, 2013, 04:16:11 PM »
Those things you put in the exhaust to measure the air/fuel mixture....the knowledge to FINE tuning that I don't have...:(
I need to rebuild my front brake caliper. Trying to chase down a squeak.
« Reply #271 on: June 11, 2013, 04:41:58 PM »
The squeak may not be the caliper but the rotor and pads, a very common issue (my K4 is notorious).
Do a search for some remedies that guys have done including new pads, lube and scuffing the rotor.
fendersrule
« Reply #272 on: June 11, 2013, 05:12:41 PM »
It's got new pads, and I definitely lubed the back of them quite well.
It happens independent of braking, even though I think braking makes it go away.
Same with you?
« Reply #273 on: June 11, 2013, 07:03:05 PM »
Same with you?
No, mine squeals when brake is applied.
fendersrule
« Reply #274 on: June 11, 2013, 09:08:22 PM »
Yeah. That's normal for these bikes.
I'm thinking my caliper needs a rebuild, though I can't find any rebuild kits for a k. Then I need to see if I need a piston to go along with it. Ugh!
