Author Topic: Sun rims Update.. Need insight 40 spoke but 3 stem valve punched?  (Read 2966 times)
Offline Tews19
  • I am no
I came across a set of Sun rims yesterday and notice some engravings.... First rim is engraved  03B 1174.......... From what Mr. Google provided, this rim is a NOS Hallman Racing Sun Metals Rim Wheel Hoop CR125M CR250M Elsinore 18 x 2.15, Made November 1974.
Second rim is a Sun too. This one was engraved with 04B 974..... Is this the same rim???  One front one rear?????? Different build date obviously.....
Since 36 holes does this mean they are for a 550? As I think the 750 uses 40 spokes... Correct?
These have never been used and from what I see, if Hallman rims which i know one is, they go for crazy money....
« Last Edit: January 07, 2013, 08:57:54 AM by Tews19 »
1970 Honda CB750 survivor.
Offline luap
  • LAWL
Re: Sun rims for CB550 or 750? Hallman racing??????
« Reply #1 on: November 11, 2012, 04:08:04 PM »
All the 550 ive had have had 40 spokes. Couple bikes ive seen with 36 spoke. 125, 200, 350, an I believe some of the early 400 had 36 also.
you gonna put a couple pics
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Tews19
  • I am no
« Reply #2 on: November 11, 2012, 04:11:56 PM »
Pics posted.... I have yet to wash the dust off of them... Damn, I always thought the 550 had 36 and 750 40... Man, looks like I have a sent of Akronts that I can't use either as I got same 18x2.15 40 spoked ones of those.
« Reply #3 on: November 11, 2012, 04:16:37 PM »
Those are rear rims for CR125 and CR250 Honda 2-stroke dirt bikes.
Offline Tews19
  • I am no
« Reply #4 on: November 11, 2012, 04:19:25 PM »
I thought I was able to use the rims for the 550 and the other for 750... Looks like I was wrong... Damn it
Offline luap
  • LAWL
« Reply #5 on: November 11, 2012, 04:22:10 PM »
those ones you can use unless 40 was a typo
why not find a 36 hole hub an build them. maybe do a straight 8 guage for some strength
www.cb-town.com
Offline Tews19
  • I am no
« Reply #6 on: November 11, 2012, 04:42:33 PM »
I didn't think about that..... I will look around ebay for hubs but if I can't find the proper ones I will list on Ebay... This sucks, the sun rims I got but they really nice..... The Akronts, I thought I would be able to use on my next 750 project...
« Reply #7 on: November 11, 2012, 04:58:31 PM »
 I told you Yam 650 twin hub can be made go work with 36...i think..
Offline Tews19
  • I am no
« Reply #8 on: November 11, 2012, 05:11:02 PM »
Frank, how will the rear hub work? Same thing, look for an XS 36 hole rear?
Offline 55fbomb
« Reply #9 on: November 11, 2012, 05:40:26 PM »
Possilby a 2 stroke suzuki also, i believe those were 36 spoke with 20mm rear axle.
or maybe im just dumb . . .
« Reply #10 on: November 11, 2012, 05:52:18 PM »
 I was talking front.
Offline Tews19
  • I am no
« Reply #11 on: November 11, 2012, 05:54:00 PM »
Frank, I found this. Have to contact the seller but is this the correct yr?
http://milwaukee.craigslist.org/mcy/3336414874.html
« Reply #12 on: November 11, 2012, 06:05:26 PM »
You might be able to sell the rims to someone restoring a vintage Honda motocross bike. Much easier than trying to find a hub and fitting it to the rim. ;)
« Reply #13 on: November 11, 2012, 06:52:10 PM »
 Yeah but I think that one is sold, some are dual disco tapped, but you got to look under the tin cover..
Offline Tews19
  • I am no
Re: Sun rims Update.. Need insight 40 spoke but 3 valve cut?
« Reply #14 on: January 07, 2013, 08:57:20 AM »
I was out putzing with the 750K4 last night and decided to take a look at my Sun rims again..
I miss counted the spoke holes... I counted 40 of the spoke holes but the weird part is the 3 holes that are bigger.. They seem evenly spaced on the rims... Can someone tell me if these are an odd/ mispunched rims that are useless?
Pics showing the bigger diameter holes... Only 3 as stated. Since they have 40 holes minus the 3 which I think may be for valve stems, would these be able to be used on a 750?
« Last Edit: January 07, 2013, 08:59:49 AM by Tews19 »
oldbob
Re: Sun rims Update.. Need insight 40 spoke but 3 stem valve punched?
« Reply #15 on: January 07, 2013, 09:15:58 AM »
I suspect that two of those three holes are for rim locks, pretty much what I would expect for dirt bike rims.
Bob
Offline Tews19
  • I am no
« Reply #16 on: January 07, 2013, 09:25:12 AM »
Rim locks? No idea what those are. So these are useless for a 550 or 750.. ehhhhh damn it
Offline Xnavylfr
« Reply #17 on: January 07, 2013, 09:38:20 AM »
NOT rim locks ,, BEAD locks, once the tire is mounted ( OFF ROAD TIRE) the beadlock is tightened down to hold the tire on the rim. Almost a priority to have for dirt bike!!!
Xnavylfr(CHUCK)
Offline Tews19
  • I am no
« Reply #18 on: January 07, 2013, 09:43:22 AM »
Xnavylfr(CHUCK)
Thanks all! Much appreciated
Offline Doum
« Reply #19 on: January 07, 2013, 09:45:41 AM »
My 2 Z1R-TC have 2 lock on the rear wheel,it's the first time I saw a street bike with lock,especially 2
Offline Raul CB750K1
« Reply #20 on: January 09, 2013, 02:36:23 AM »
If you want to use those rims without the locks, there are some rubber plugs to put in the holes. I've seen them on rims, but can't tell where to buy them.
Offline shinyribs
« Reply #21 on: January 09, 2013, 09:02:15 AM »
Yep. Rim locks is what they are most commonly called. FWIW I had a rear tire that going flat a while ago and found out that my rear tire had spun on the rim and ripped the tube. It might be a good idea to use a rim lock if you have a good runner ;)lol
But on the spoke count. Once you subtract the valve stem hole,  and the two rim lock holes,then you still have 40 spoke holes left,right?
A 40 spoke rim is a 40 spoke rim. It has no idea what hub you lace it to. The rims you have here dont have directional dimples so you dont have bad nipples angle working against you.
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline Tews19
  • I am no
« Reply #22 on: January 09, 2013, 09:04:38 AM »
Thanks for the insight! Now I may use them!
Offline shinyribs
« Reply #23 on: January 09, 2013, 09:10:43 AM »
It just occurred to me the thought of trying to balance a tire with a rim lock in it :o LOL. So please understand I was just messing around about running the lock...that is unless they are 180 degrees out ;)That would probably balance out OK.
Please post pics if you use these rims. I kinda dig the fact that they dont have nipples dimples. Clean look
« Reply #24 on: January 09, 2013, 09:16:55 AM »
The holes are still drilled at an angle of some sort. The depth of the thickness of the rim. So there may still be an angle issue of the spokes. Especially on the rear where the spoke enters the rim at a steeper angle than the front. Pop a nipple in the hole and see where it points when its laying flush in the hole. I'll bet its not towards the target on the hub. Then if you kant it up on its edge to get it pointing right, well, is that good?
