Author Topic: Tank decal replacement on a Fat striper  (Read 4359 times)
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« on: November 12, 2012, 06:20:06 AM »
New K3 decal/stripe process lastnight... 8)
Blue painter tape is for new placement of decal.
Process took about 2 hours from start of heat gun removing old stripe till new
stripe was "floated on"
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline CycleRanger
  • No comment about being an
Re: Tank decal replacement on a Fat striper
« Reply #1 on: November 12, 2012, 07:19:41 AM »
That looks nice!  The old stripes weren't under the clear?
Offline bjatwood
  • 1973 CB750-K3
« Reply #2 on: November 12, 2012, 07:35:58 AM »
No, that paint is OEM on the tank and this bike is pretty much a unmolested/survivor. So, I do not believe Honda cleared over the stripes. Have you heard they did?
Brian
#24193
Offline Killer Canary
  • Typical Bran Muffin
« Reply #3 on: November 12, 2012, 07:43:29 AM »
I just did the same thing on a 550. Were your new graphics pre-cut or home-made?
Kawi GPz900, H1
Offline bjatwood
  • 1973 CB750-K3
« Reply #4 on: November 12, 2012, 07:57:17 AM »
Precut, got em from a company in the UK. Couldn't find the K3's stripes very easily.
The K3 stripes are a one year specific stripe that looks almost like the 74-76 tanks but the white stripe is way smaller on the K3's... ;)
Brian
#24193
Offline Dream750
« Reply #5 on: November 12, 2012, 09:23:32 AM »
Very impressive work! ;)
Any plans to restore the emblems back to original?
Offline bjatwood
  • 1973 CB750-K3
« Reply #6 on: November 12, 2012, 10:05:17 AM »
Thanks,
Some K3's actually came WITH the Black lettering. Not sure why Honda did this. But when I got my bike I enquired on this site about this and was told by numerous owners that some of the emblem letters where Black and all of them went to white lettering by 74... ;)
Just the way it rolls I guess.
I do prefer the white lettering, but will never modify this bike tho. All stock for me is how I roll  8)
Brian
#24193
Offline Dream750
« Reply #7 on: November 12, 2012, 11:08:08 AM »
Well, I’ll be ... :o
Yours is the first K3 I’ve seen with black letters, which makes your bike unique having a rare and original Honda part. Did I mention the cool factor?
Original example bikes are my personal favorite too!
Offline bjatwood
  • 1973 CB750-K3
« Reply #8 on: November 12, 2012, 12:14:24 PM »
I've seen a few of them, especially on eBay. A member here on the site GrandRapids750K3  actually has one with the Black letters too  ;)
« Last Edit: November 12, 2012, 12:18:14 PM by bjatwood »
Brian
#24193
Offline bjatwood
  • 1973 CB750-K3
« Reply #9 on: November 13, 2012, 05:18:10 AM »
Here ya go "Dream750" a museum 1973 CB with Black HONDA lettering...
Brian
#24193
Offline jerry h
« Reply #10 on: November 13, 2012, 07:10:00 AM »
Your new stripes look nice!   ------   I think I would be a nervous wreck trying to get the old ones off without harming the tank.  Any secrets to that process, or do they peel off easily after some heat is applied?
Offline bjatwood
  • 1973 CB750-K3
« Reply #11 on: November 13, 2012, 11:12:17 AM »
Thanks Jerry,
I was very nervous on the first side. I have had the decals for about 6 months building up some courage and thinking about what I had to do.
This is the steps I followed to make sure all went off with out a hitch!
1. Removed tank from the bike, Drained all old gas out of the tank, took the petcok off and left the fill cap open.
2.  Let the tank sit for a week venting and evaporating any old gas.
3.  Brought it inside the house to the dining room table to warm up and give me ergonomic access to the tank from a seated position.
4.  Used 3M painters blue tape to mark position of the old stripe prior to removing. With my heat gun on low I started at the end of the stripe closet to the seat. And warm the stripe(tape) up so I could start peeling it off the tank.
5.  Work your way all around removing it slowly and steadily. I actually got the second stripe off in just 4 sections
6.  Clean any old adheasive off using acetone.
7. I then used some simple green to make sure everything was clean, followed by some soap and water to "make sure" all was clean
8. The new stripe was one of the double sided type where you place it in position and peel the top sheet off the stripe. I sprayed the side of the tank liberally with a spray bottle (12oz) full of water and 4 or 5 drops of dishsoap to float the decal into exact position.
9. Peel the top cover off the new stripe and "re" position the new strip into exactly where it needs to be working from the front of the tank towards the back.
10. When the stripe is where you like it, squeegee the water out from under the stripe using a credit card to "push" the water out and wipe the water off using a clean terrycloth towel.
11. If you have some spots on the new stripe that have some bubbles or wrinkles, use a pin to expel any air and then hit the area with the heat gun on low for like 3 seconds and you can push the vinyl with your finger down and hold it for 10 seconds and when you remove your finger the spot is litteraly gone. Heat gun any wrinkes using the same method except NO pin LOL The heat makes the vinyl very easy to work with.
12. Stand back and have your favorite "beverage" and admire your handiwork  ;)
« Last Edit: November 13, 2012, 11:15:23 AM by bjatwood »
Brian
#24193
Offline mono
  • Definitely no
« Reply #12 on: November 13, 2012, 11:23:17 AM »
nice work - looks great!
Offline Dream750
« Reply #13 on: November 13, 2012, 12:58:56 PM »
bjatwood, many THANKS for posting up the K3 photo!
I’m glad to have stopped in on your thread as I learned two new things: first was the tank stripes can be replaced without disturbing the original factory paint and second, some K3’s do have black tank emblems. :)
Offline CycleRanger
« Reply #14 on: November 13, 2012, 01:36:38 PM »
Yeah, I thought the decals were under the clear.
Both my 750's have been repainted and the stripes were painted rather than decals.
I guess I need to look closer next time I see an original paint tank.
Offline bjatwood
  • 1973 CB750-K3
« Reply #15 on: November 13, 2012, 05:38:59 PM »
Very humbled to be of service to my fellow Brothers of SOHC's  :D
Brian
#24193
« Reply #16 on: November 13, 2012, 07:45:54 PM »
I didn't think Honda used clear back then?
Offline bjatwood
  • 1973 CB750-K3
« Reply #17 on: November 16, 2012, 11:43:52 AM »
O yes Steve-O,  Clear was definitely used by Mother Honda
Brian
#24193
Offline CycleRanger
« Reply #18 on: November 16, 2012, 11:53:05 AM »
Yeah metal flake candy.  Silver/metal flake base coat, transparent candy color, then clear.
Offline bjatwood
  • 1973 CB750-K3
« Reply #19 on: November 16, 2012, 12:38:49 PM »
You got it right on Cycle Ranger!
Brian
#24193
