Author Topic: Will the Dynoman 592 pistons work with a CB650 cam  (Read 1257 times)
Offline akabek
« on: November 12, 2012, 12:33:37 PM »
I just ordered the Dynoman Street DP592/SV pistons and I was planning to use a CB650 cam.  Will this work or should I be looking at the Dynoman 58A cam?
Re: Will the Dynoman 592 pistons work with a CB650 cam
« Reply #1 on: November 12, 2012, 02:46:03 PM »
I don't think there's much difference between those cams so likely no problem, but you should always pre-assemble to check clearances anyway.
