Author Topic: Swingarm question  (Read 520 times)
Swingarm question
« on: November 13, 2012, 04:07:22 AM »
I think I know the answer, but still want to verify before I spent money.
To install F2 rear wheel into K3 frame I need wider swing arm - that is a fact, tried it with K0 and it does not fit.
Wider swing arm can be from 76, 77 or 78 Cb750K or from CB750F1/F2  - correct or not?
Wider swing arm will fit into K3 frame with minimal adjustmens - correct or not?
Thank you.
Offline Old Scrambler
Re: Swingarm question
« Reply #1 on: November 13, 2012, 06:18:45 AM »
You can exchange the sprocket carriers to properly align the wheel with the K3 motor-sprocket.  If you switch the swingarm for the wider sprocket you will have to get an off-set sprocket from Cycle-X..........F2-3 with disk brake & K7-8 with drum. You will also need to exchange or modify the chaingaurd.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: November 13, 2012, 07:03:03 AM »
Thank you.   I have actually F2 engine to go to that K3 frame - it will line up just fine.
Offline H2Eric
« Reply #3 on: November 13, 2012, 08:52:22 AM »
If you attempt to use the later swinging arm in the K3 frame I think you will find that the shock absorber mounts will not line up.
Good luck
Eric
Honda CR750
Honda CB750K3
Kawasaki 750H2B
Suzuki GS750
Honda CB175
Honda CB350F
Yamaha R1
http://forums.sohc4.net/index.php/topic,94588.0.html
Growing old is mandatory, growing up is optional.
« Reply #4 on: November 13, 2012, 09:26:45 AM »
Yes, I expect that.  I will need to reweld them to line them up. Should not be a big deal since I have to fab bracket for the rear master cylinder too.
