Author Topic: new from nebraska  (Read 567 times)
Offline lessthanzero
new from nebraska
« on: November 14, 2012, 04:34:19 PM »
hey all,
i'm glad i found this forum.  it is full of great information and help.
i currently own:
1977 cb750f
1978 cb750f
to use an analogy from zen and the art of motorcycle maintenance,  i am currently the rider who enjoys riding without the knowledge of how the motorcycle works or how to repair it.  but i am on the path to become the other rider who knows his motorcycle and is able to work on it himself.
Re: new from nebraska
« Reply #1 on: November 14, 2012, 06:32:55 PM »
Welcome from NY. With these old bikes you will learn how they work and how to fix them quick. :D :D :D
« Reply #2 on: November 14, 2012, 07:28:43 PM »
thanks for the welcome BobbyR!
here's what i am working on:
i was riding the '77 on the highway, and it started running poorly. the oil light turned on but i decided to ignore it because i just had it inspected and the oil changed. (such a regretful mistake) the engine blew up in dramatic fashion, smoke billowing out of it.  when i pulled off to the side of the rode, i saw that i had blown two large holes through the bottom end of the motor.
i purchased the '78, which is in much better condition overall, but has a problem with the top end.  i am hoping to swap the good parts from the '77 into the '78 and have it up and running again before winter is over.
some other things that are on my mind:
i haven't opened up either engine yet, so i do not know the condition of either, and i am probably naive to think that i won't be opening up a can of worms.
i don't know if i should just look into buying new top end parts for the '78 while also searching for a new case for the '77 so that i'll have two working motorcycles some day instead of just one.
i just acquired many of the tools i'll need today for this project and will start the process of removing the engines from their frames this weekend.  i am referencing the shop manuals, clymer's manual, and this forum. it will be a slow process because i am brand new at all of this, including working on anything mechanical.  any advice is greatly appreciated.
« Reply #3 on: November 14, 2012, 09:11:00 PM »
wow...this is the first I've heard of a windowed case!...you are alucky guy :P...I would suggest finding a running motor to drop in one of your bikes to ride while you take your time building a nice motor...rebuilds on these are quite expensive and time consuming, even when you didn't break anything.  Welcome to the forum.
Offline deafanddiabetc
  • Deaf and Diabetic.
  • Books, bikes, boards, hermit and half deaf.
« Reply #4 on: November 14, 2012, 11:45:49 PM »
@lessthanzero, is that a Easton Ellis reference? If so, kudos.
Also, Lincoln here. We have a couple guys in town and I'm always looking for others to work/hang with.
Welcome to the forum!
« Reply #5 on: November 15, 2012, 07:31:04 AM »
Lincoln is Kawasaki territory!
Offline Jerry E.
« Reply #6 on: November 15, 2012, 05:10:31 PM »
 I am also in Lincoln, Nebraska. I am working on a K3 cafe project, and an engine rebuild is indeed pricey. Buy Hondaman's book, it's got lots of useful info regarding inspection/rebuilding, if you go that way. Welcome to the forum-lots of helpful people here. And parts, too.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #7 on: November 18, 2012, 03:15:57 PM »
@deafanddiabetc yeah, that's an ellis quote. glad to see there are multiple nebraskans on here. @jerry e. i will look into hondaman's book, i need all the references i can get.
i will be removing the motor from the '78 in the next couple of days and seeing what's hung up inside.  Everything is detached, just need an extra hand removing it from the frame.
@seanbarney41 i think that's a good idea to find a running motor in the meantime, but it seems like that might be tough in my area. I think most will come with the rest of the bike and I don't have room for another. Maybe I'm wrong though?
