Author Topic: '75 CB550K rear bearing retainer thread direction  (Read 1468 times)
Offline db22
  • Old and in the way.
« on: November 14, 2012, 05:12:56 PM »
Time to change out my wheel bearings, now that snow has already fallen here.  In researching bearing changes, I have found posts stating that some 550 rear retainers are left-threaded, some right-threaded.  As far as I can tell, my wheels are original to the 1975 frame . . . so should I pound the wrench clockwise, or counter-clockwise?  I made a retainer tool as demonstrated in a post here, and it seems to fit the retainer well enough.  But the retainer is really tight -- I tried penetrating oil, will try a bit of heat from a torch this weekend.  I just don't want to wreck it by pounding in the wrong direction.  Thanks!
1975 CB550K (rider)
1975 CB550K (shaping up, slowly)
I may be goin' to hell in a bucket, but at least I'm enjoyin' the ride. . .
Offline luap
  • LAWL
Re: '75 CB550K rear bearing retainer thread direction
« Reply #1 on: November 14, 2012, 05:23:15 PM »
wont go any direction until  you drill out the holes
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline fiolola
« Reply #2 on: November 14, 2012, 08:24:33 PM »
to loosen clock wise.may be a little tight at first.
bollingball
« Reply #3 on: November 14, 2012, 08:28:40 PM »
+1 for luap Have you drilled the stakes???????
Ken
« Reply #4 on: November 15, 2012, 12:47:56 AM »
the front hub has a normal thread and the rear is always a reverse,or left hand thread.
Offline CapeCafe
« Reply #5 on: November 15, 2012, 08:28:14 AM »
Definently take a small drill bit, find the indent/pin in each of the holes on the retainer ring and drill down about a 1/8".  Once the peens are drilled, use your retainer removal tool and turn counter-clockwise.  Be careful to keep the hub flat as possible to reduce the possibility of cross threading as the retainer comes off.   When you go to put the retainer back on, take care again to keep the hub flat and make sure the retainer is threading smoothly. Take it all the way down until snug and the drill holes (removed peens)show in each of the retainer holes.  Lastly I give each hole a drop of blue loctite.  good luck
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline CapeCafe
« Reply #6 on: November 15, 2012, 08:30:39 AM »
Sorry!  I meant to say clock-wise.  The retainer is reverse threaded.  Turn right
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
Offline greenjeans
  • 1972 CB750K2
« Reply #7 on: November 15, 2012, 10:27:30 AM »
A heat gun and PB blaster go a long way towards loosening that thing up as well.
Offline db22
« Reply #8 on: November 15, 2012, 07:04:42 PM »
Thanks to all for the informative replies!  I can't find any spots where the retainer was peened to lock it.  I'll go over it again with a magnifying glass, but I always assumed they'd be easily visible.
1975 CB550K (rider)
« Reply #9 on: November 16, 2012, 01:12:32 AM »
just get a punch and with care knock it in the undo(clockwise in this case)in each hole one by one,thatll break it loose,itll come off,,its a very fine thread,,be sure to clean both before you put it back together,,use a little engine oil on the threads.
Offline db22
« Reply #10 on: November 16, 2012, 05:06:40 PM »
Hoping to get back to it this weekend (gotta work all day tomorrow)...thanks again to all.
1975 CB550K (rider)
