Author Topic: Exhaust bolt length for CB750  (Read 6374 times)
Offline eelliiss
« on: November 16, 2012, 07:14:05 AM »
Hey, I managed to misplace my original phillips head bolts/screws for the exaust into the heads.  Planning on moving to a hex.  Does anyone know the exact length?  8M x 1.25 x ???
Thanks in advance.
Offline MattFreeman
  • What Have I Done?
Re: Exhaust bolt length for CB750
« Reply #1 on: November 16, 2012, 07:17:31 AM »
So you mean the exhaust studs?
Offline eelliiss
« Reply #2 on: November 16, 2012, 07:18:50 AM »
Sure.  Whatever bolts the exhaust into the heads.
Offline eelliiss
« Reply #3 on: November 16, 2012, 07:24:16 AM »
Acutally, upon further review, I think that the original studs were removed in favor of an alternative.  What would the length need to be for a bolt if the original exhaust stud was removed?
Offline markb
  • When I finish my current project I might be a
« Reply #4 on: November 16, 2012, 07:24:27 AM »
On early CB750s the screw that goes into the head is an M8 x 1.25 flat head.  The length is 22mm.  I don't think you'd want to use a hex head on a countersunk hole and I'm not sure there would be enough room for the clamp.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline eelliiss
« Reply #5 on: November 16, 2012, 07:27:55 AM »
I'm running Carpy's exhaust, so there is no countersunk hole or clamp...unless I'm misinterpreting what you are saying.
Offline markb
« Reply #6 on: November 16, 2012, 07:58:08 AM »
Then never mind  :P
Offline Mo
« Reply #7 on: November 16, 2012, 08:20:30 AM »
Some pictures would be helpful? Also, just a general comment, but if you at all can, use studs. They'll keep the threads in the head from wearing down over time.
Offline eelliiss
« Reply #8 on: November 16, 2012, 08:28:30 AM »
No pictures at the moment, but good advice.  I could've sworn that someone once wrote that the length was 35mm, so that's what I got.  When I got them, they looked much longer than what I remember the original screws being.  Last night, I hand tightened one of the new bolts in, and they bottomed out quite abit before the end of the bolt.
« Reply #9 on: November 16, 2012, 08:32:20 AM »
Here's how it goes: The early pre-K2 or so CB750s used a flange that was held into the head with 2 flat head (taper tops) screws. The pipe then slid onto the spigot of the flange and was clamped in place with a large finned clamp.
later 75os used 2 studs out of the head and the exhaust pipe had a flange on it. The pipe was inserted into the head, the flange was drawn towards the head with nuts on the studs.
Often the early style is converted to the later style to accept an aftermarket exhaust pipe.
On the later style, bolts can be used instead of the stud/nut affair.
Offline eelliiss
« Reply #10 on: November 16, 2012, 08:46:44 AM »
Thanks for the reply.  I guess I'll try the 22mm and see how that works.
Offline markb
« Reply #11 on: November 16, 2012, 08:58:31 AM »
Then measure the gap under the head, and a mm or two and subtract that from 35mm.  That will get you real close.
Offline eelliiss
« Reply #12 on: November 16, 2012, 09:11:37 AM »
That would make way too much sense.
Offline MattFreeman
  • What Have I Done?
« Reply #13 on: November 16, 2012, 11:35:10 AM »
For my 76 F I'm using 60mm allens with a nut between the flange and the bolt head to tighten the header to the head. Sounds like mine might use a longer bolt but the principal could be used anyhow and would put less stress on the head.
Offline kmb69
« Reply #14 on: November 16, 2012, 11:56:55 AM »
They are available in socket head countersink for the spigot type exhaust. Example:
http://www.ebay.com/itm/HONDA-CB750-EXHAUST-BOLTS-NEW-STAINLESS-CB-750-CAFE-8-/370620058683
Probably available for less money from a standard fastener source.
« Last Edit: November 16, 2012, 12:00:06 PM by kmb69 »
Offline eelliiss
« Reply #15 on: November 16, 2012, 12:09:24 PM »
Thanks for being such a helpful bunch!  Among the best guys of any forum I've been on.  Be prepared for more silly questions in the future, dudes.
Thanks-a-million!
Offline nobody
« Reply #16 on: October 11, 2016, 10:35:11 AM »
Why would using countersunk bolt heads be a bad idea?
I'm looking to run Cycle X exhaust and far as I can tell I need bolts 1/2 inch longer than stock.
74 cb750k
« Reply #17 on: October 11, 2016, 10:42:23 AM »
Convert to studs, and draw the exhaust to the head with washers and flange nuts.
Less of a chance stripping the bolt holes with repeated exh removals for oil changes  ;)
« Reply #18 on: October 11, 2016, 11:01:31 AM »
Or leave flanges on and  have 3minute removal for the whole header.
« Reply #19 on: October 11, 2016, 11:10:15 AM »
I think he's running carpys yosh replica, Frank.  But yeah, thats an easy removal.
« Reply #20 on: October 11, 2016, 11:13:37 AM »
+1 on studs.  Steel stud in the engine eliminates repeated loosening/tightening steel - Aluminum.
« Reply #21 on: October 11, 2016, 11:03:09 PM »
So does the spigot, it never gets loosened.
Offline pjlogue
« Reply #22 on: October 12, 2016, 03:48:47 AM »
I used these:  https://www.nutty.com/search.asp?keyword=XMFSC825
Use antiseize  on the threads.  Length was a little longer than the original bolts but had plenty of leeway in the hole.
This company is a great source of stainless hardware and price is very low compared to your neighborhood hardware store for metric stainless.
-P,
