Author Topic: Stator rotor testing  (Read 584 times)
Offline mattporter637
« on: November 16, 2012, 12:41:28 PM »
Does anyone know how to test the resistance on a 1978 cb550 stator rotor. The 650 and 750 have a plate on the end which is easy to check but how do I determine if the rotor is good or bad on my bike?  I have two of these 550s and I am unable to remove either of the rotors from the bikes. I have taken an impact to the nut on the end of the pressed shaft and that still won't loosen it. I know how to press it out once I loosen the nut but I can't get the damn nut loose on either of the bikes. Thanks.
Re: Stator rotor testing
« Reply #1 on: November 16, 2012, 07:33:15 PM »
There is no resistance test on the rotors of any of the sohc fours, except the 650. They are basically a couple of lumps of steel welded together, and don't go "bad".
« Reply #2 on: November 16, 2012, 08:29:46 PM »
Yeah that's what I was thinking. I had just read some and watched some YouTube videos on guys testing the rotor. Thanks.
