Author Topic: cb750k4 how to plug up the chain oiler!??!  (Read 13024 times)
Offline killersoundz
« on: November 18, 2012, 01:12:04 AM »
Is there any standard way of cutting off the chain oiler? Thing keeps pissing oil all over my motorcycle room! Mostly drips down the kick stand. 100% sure it's from the chain oiler as I loosened it up one time and it poured out a ton. I have it as tight as it goes but still have little puddles  >:(
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
Offline dhall57
Re: cb750k4 how to plug up the chain oiler!??!
« Reply #1 on: November 18, 2012, 06:41:53 AM »
Loosen large center nut and than use small screwdriver and tighten down center screw and than re-tighten large nut. No more chain oiler.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline WhyNot2
  • I'm finally an
« Reply #2 on: November 18, 2012, 06:47:51 AM »
Me too, changed my sprockets and chain, now I get puddles down the kick stand too.
Didn't happen till I changed them. Guess I have to do the same................................!!
Good Luck !
« Reply #3 on: November 18, 2012, 08:08:52 AM »
 There is a company making some, not sure they are o ring sealed. I made up a couple , a bit more involved than I had thought. Have not had a chance to test them.
Offline Dream750
« Reply #4 on: November 18, 2012, 08:38:15 AM »
Here’s a cheap option, but I haven’t personally used it.
http://jokermachine.com/products/cafe-racer/honda-cb750-parts/cb750-chain-oiler-plug.html
« Reply #5 on: November 18, 2012, 10:28:13 AM »
It could also be the counter shaft seal, or a cracked case is very common in this area.  Clean up the case very carefully around the sprocket and check for cracks.
Offline andrewk
  • doin' it.
« Reply #6 on: November 18, 2012, 11:34:44 AM »
Shouldn't matter, but I cringe at the thought of putting silicone sealer in the output shaft.  Would be effective though.
« Reply #7 on: November 18, 2012, 12:22:35 PM »
I've got that center screw tightened up all the way already.
I'm pretty convinced 99% it's from the chain oiler since it only started doing this after I loosened the center screw of it up a bit to see what happened, and what happened was a huge puddle of oil, then I tightened it up again....
This is what I'm dealing with just little drops
My project thread:
Offline Dream750
« Reply #8 on: November 19, 2012, 04:53:19 AM »
I agree. The Joker plug is an affordable option for the OP and others. The Yamiya plug is better design, but much more expensive:
http://www.yamiya750.com/index.php?main_page=product_info&cPath=21_53&products_id=115
« Reply #9 on: November 19, 2012, 07:49:38 AM »
The Yamiya does not use an Oring, looks like the KO shafts are different in the bore maybe. Not sure how that locktab would work on Yamiya.
 The O ring ones I made would come in under that price.
« Reply #10 on: November 19, 2012, 07:58:06 AM »
What is the thread on it, Frank, would you know?
« Reply #11 on: November 19, 2012, 08:03:38 AM »
 Will try to get pics, think it was 12 mm, made them out of 7075, with a hollowed out hex head..
« Reply #12 on: November 19, 2012, 08:11:45 AM »
Thanks!
« Reply #13 on: November 19, 2012, 08:16:54 AM »
You can cut the top off of a sparkplug and run that in. The part has to go in far enough to cover the hole that lets the oil out, which resides under the sprocket.  Any plug you use must be as long as the threads on a sparkplug "E". (First hand)
Several threads on this subject. I think a FAQ talks about removing the sprocket, cutting an ORing and threading that thru the hole.  (never tried it)
The Yamiya piece is OEM and won't turn the oiler off IMO.  Doesn't look like the Joker piece goes in far enough either, though pushing some silicone in advance of the plug may reach the hole.
Finally, if you ever have the cases open remove the catch tray that funnels oil into the drive shaft. That will cut it off permanently. (First hand knowledge)
« Last Edit: November 19, 2012, 08:29:28 AM by MCRider »
« Reply #14 on: November 19, 2012, 09:43:49 AM »
I like the spark plug, true MacGyver  ;D
Well that makes it M12x1.25 thread.
« Reply #15 on: November 19, 2012, 01:52:19 PM »
 It's 14. MM.
 Took a bit of figuring. To come upwith my design, yes that hole needs plugging, is a long ways in.
 Here is my, thought out design.. And it weighs 11 trams..
« Reply #16 on: November 19, 2012, 01:53:41 PM »
 Look at these..
« Reply #17 on: November 19, 2012, 01:57:37 PM »
It's 14. MM.
14mm. Really?
Those are cute. Make one want to run without the cover.   :D
« Reply #18 on: November 19, 2012, 10:30:00 PM »
 If you build a bike part, it should look nice, and save weight..jmo..
« Reply #19 on: November 20, 2012, 12:33:32 AM »
Very nice, Frank!
Offline Dream750
« Reply #20 on: November 20, 2012, 06:11:10 AM »
The early K0 up to engine number: CB750E-1026143 used a different shaft and a solid plug design. Oil flow control on those engines was adjusted by adding or removing shims between the plug and shaft. Later OEM plugs had an adjusting screw. Note the differences between the early and late type of plug thread design:
http://www.yamiya750.com/index.php?main_page=index&cPath=21_53
The lock tab inside ear fits in the valley of the shaft splines to prevent rotation, then the outer ears are bent over to secure the plug.
BTW: Your prototype plug looks great and I want one. ;)
« Reply #21 on: November 20, 2012, 06:26:36 AM »
I think, also, IIRC, the OEM plug we are looking at here, could never turn the oiler completely off, regardles of the thickness, or lack of, washer. The later adjustable plug was also considered an upgrade to the early plug, a retrofit. But even it at full "off" mode, still allowed a drip to get thru.
I'm fairly certain the thread size is a 12mm as I am certain that a sparkplug will do the job and its 12mm. Have to hack saw or break the top off of it, so it will fit. Not too elegant perhaps, but functional.
« Reply #22 on: November 20, 2012, 06:40:16 AM »
I have it screwed all the way in and it still keeps dripping, just a little bit, but enoough to leave a spot.  I think I need to plug it.
Frank, are you going to make few of those?
« Reply #23 on: November 20, 2012, 07:17:22 AM »
 I will try to get  some more , turned and milled. The tricky part is getting it to seal. Sparkplug would get the end,  but not plug the side hole..
  I forgot about the locktab  going in the spline just like stock part.
« Reply #24 on: November 20, 2012, 07:38:00 AM »
I'll check again tonight, but my memory is that if you use the "E" length plug, standard in our motors, not the 12mm/"H" length plug which is shorter, the threads are long enough to cover the hole and seal it off.
OCICBW
Not to say one shouldn't use a trick hand made part if one were available. Lord knows I've bot my share.
One could silicone the spark plug in place which seems to be OK per Joker. Or LokTite. But I'd rather have something that the OEM lock tab could bite into, for piece of mind. The spark plug hex is too far away from the end of the shaft for the OEM lock tab to work.  I'd hate for what ever i put in that hole to ever come out.
In my case, I already pulled out the collection pan, so I'm not in the market. The stock adjustable affair is in place but does nothing but keep the bugs out.
« Last Edit: November 20, 2012, 07:39:42 AM by MCRider »
