« Reply #48 on: May 17, 2022, 01:12:09 AM »
(how much pressure does that oil feed have?)
There is zero pressure: the oiler is fed from the oil/air separator drain in the oil tank, which is somewhat inconsistent, depending mostly on engine RPM.
So is there a feed hose from the tank directly to the oiler then? The reason I ask is pieces of the puzzle in my remembering threads and conversations coming together, and I was over at Anders shop last October, talking with him about getting one of his high output alternators and he mentioned the K6 oil tank was different than the K5 and earlier tanks and was a good thing to use with his setup for clearance of mounting the R1 regulator/rectifier.
I know on the K6 Honda eliminated the chain oiler(double checked the K6 bike I have and remember that from the time in the parts room learning the 750s in the 70s. Not all is forgotten yet......
Well another sleepless night.... There seems not to be a hose from the tank as I surmised but there is a tray in the case that collects the oil to deliver the oil to the oiler. Still learning at 65....
Logged
Stu
My current rides
Prior bikes....
