Author Topic: 1977 CB550F IDK (first build)  (Read 174173 times)
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: 1977 CB550F IDK (first build)
« Reply #600 on: November 12, 2015, 12:45:13 PM »
Gotcha, calj! I'm on it. Thanks!
« Reply #601 on: November 12, 2015, 12:54:26 PM »
Make sure that's the only thing all FUBAR.  Otherwise, you may need additional parts from that donor.
Offline minimo
« Reply #602 on: November 12, 2015, 01:17:12 PM »
Giving my old back a little rest before I jump into crouching tiger mode again - splitting the case.
Circling back to my battery drain issues for a quick minute.
I didn't meter the battery like I probably should have before the last ride but the headlight looked strong for about 20 minutes worth the pavement time and then the mishap... I was parked in a dark area so for the tow driver to see me I kept the lights on for a short while and watched the lights dim gradually - I imagine that's normal considering the size of the battery (?) but just in case my wiring is still a mess, calj737, can you see something here that can be corrected (other than the cramming)?:
Normally, I would have the reg/rect mounted under my electronics tray but I've brought it up to show you. So, just as the instructions say, I connected the new harness directly into the old rect harness, new Grn connects to reg Wht, and new Bwn I ran up to the ignition Blk, as you suggested.
A while back I cleaned up my old solenoid and put wires back that could be mistaken, perhaps. Can you take a look:
I have the thin YELLOW/RED and GRN/RED connected to their corresponding connectors. I imagine there's no specific post that's either left/right or #1 or #2 but on one of the posts I have a thick (4 AWG, I think) red line going to the battery combined with another red (about 8 AWG) that's part of the old wiring bundle. On the other post is only a thick (maybe 8 AWG) black line that connects to the starter. So far so good? Something amiss?
« Last Edit: November 12, 2015, 02:52:55 PM by minimo »
Offline minimo
« Reply #603 on: November 12, 2015, 01:36:41 PM »
...and from the old REGULATOR, I have an old BLACK and GREEN are loose and not connected to anything. Is this normal? Does black need to tie in the new reg/rect somehow? Green?
Offline calj737
  • I refuse...
« Reply #604 on: November 12, 2015, 02:11:24 PM »
Solenoid is fine as is.
From your new Reg/Rec, list the wire colors please. It should be:
3 Yellow
1 White
1 Red
1 Green
1 Brown
Is this what you have?
« Last Edit: November 12, 2015, 03:58:46 PM by calj737 »
Offline minimo
« Reply #605 on: November 12, 2015, 02:14:52 PM »
Cool on the solenoid. Thanks.
As for the new reg/rec, the wires I have are different from how you have listed. Mine go as follows:
Part of the harness:
3 White
1 Black
1 Red
1 Green
1Brown
Do I have he wrong reg/rec?
« Last Edit: November 12, 2015, 02:53:31 PM by minimo »
Offline calj737
  • I refuse...
« Reply #606 on: November 12, 2015, 02:39:35 PM »
And tell me how they match to the stator harness plug? Or, are you using the stock intermediate connectors also?
Offline minimo
« Reply #607 on: November 12, 2015, 02:45:09 PM »
Yep, stator harness plug is stock.
Offline calj737
  • I refuse...
« Reply #608 on: November 12, 2015, 03:23:51 PM »
If it were me, I'd abandon the stock intermediate plugs and simplify the wiring. I'd run the RR straight to the battery (Red) and the remainder of the wires to the stock stator plug. This removes all doubt of connections, insures charging, and guarantees a ground.
I am a bit confused between the BLK and the BRN on the unit you have though. From the Electrosport site, they don't list a BRN, and they indicate BLK is the switched 12v sensing wire. So where does your RR BLK connect currently?
Offline minimo
« Reply #609 on: November 12, 2015, 03:45:11 PM »
I'll try connecting RR Red directly to the battery as you suggest (shorter travel to the solenoid + post, would that be alright)?
RR Red connects to one of the Yellow via the harness.
Black on the RR is part of the harness and that connects to Green on the old harness...
Yeah, I'm confused with the Brown on my RR unit also when ElectroSport doesn't have it listed. Maybe I have an older unit?
Offline calj737
  • I refuse...
« Reply #610 on: November 12, 2015, 03:57:51 PM »
The stock stator plug is an 8-way. I remove the plug and separate the BL/R (oil pressure) and GR/R (neutral) from the plug and use only stator connections to solid state Reg/Recs when doing a custom harness.
From the stator, I simply color match to the stock stator colors. You will have:
3 Y
1 W
1 G
i suspect that either you have the wrong RR, or, their Whites are mapped to Y, their BLK is mapped to stock W, their G is stock G, and their RED goes to battery POS, and their BRN is switched 12v. Did your unit come with an other side plastic plug? If so, you should be able to de-pin the stock stator plug, clean the spades, and install into supplied connector and plug it all together.
You might confirm with Electrosport in the colors above, and verify whether your unit is the correct unit for a CB550.
Offline minimo
« Reply #611 on: November 13, 2015, 12:29:04 AM »
I'll have to wrap my head around that one for a bit. Meanwhile, I've written to ElectroSport so we'll see if they can offer any advice/recommendations. I noticed on their "fitting instructions" page they mention, "Note: Due to part improvements and redesigns, your part may look differant from what is shown."
Offline minimo
« Reply #612 on: November 13, 2015, 01:04:16 AM »
Well, I peeled the case apart and here's what I found:
There are bits of broken teeth from the mainshaft gear stuck in between the teeth of the countershaft gear. The shafts appear to be spinning normal with no wobble. No other gears seem to have been affected.
Looking at the parts list, the damage seems to have only involved the following:
Mainshaft Second Third Gear (22t, 26t) - part #23431-374-000
Countershaft Second Gear (36t) - part #23441-286-020
Shift forks look ok:
All I can say is that something was not right in the shifting at high speed. Ugh.
Offline calj737
  • I refuse...
« Reply #613 on: November 13, 2015, 03:49:05 AM »
I was going to ship the trans out this AM. Want me to wait until I pull down the spare engine and ship the main shaft too?
Offline enwri
  • So that noise is normal?
« Reply #614 on: November 13, 2015, 04:32:47 AM »
Ouch. Circlip keeping second away from fifth on the countershaft is my guess.
Have also done the 60kph to nothing in about 20 feet when the bolt holding the front sprocket came out, the sprocket came off and jammed in against the swingarm, locked solid, broke a tooth off it. Much easier to fix. Just as lucky not to be a smear on the road.
« Last Edit: November 13, 2015, 05:18:56 AM by enwri »
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline minimo
« Reply #615 on: November 13, 2015, 06:47:52 AM »
That's a good guess on the circlip, enwri. I'm going to to pull the gear sequence apart and get a closer look at these gears as well as the clips and washers in between them. Yeeouch on your sprocket falling off. A smear on the road though sounds a lot worse. Glad we are safe now to tell the tale.
calj737, wasn't sure what you were sending but I kinda assumed the shafts were all part of the surprise?
Sent from my iPad using Tapatalk
Offline calj737
  • I refuse...
« Reply #616 on: November 13, 2015, 06:49:27 AM »
I guess with that, the Cat's outta the bag now? I'll ship it along-
Offline minimo
« Reply #617 on: November 13, 2015, 06:53:47 AM »
Awesome kindness, calj. Thank you!
Offline minimo
« Reply #618 on: November 13, 2015, 11:51:57 AM »
Got a reply from ElectroSport:
The parts wires are as follow:
3 white -> stators 3 wires in any order
black-> ground
red-> battery positive
green->field coil.  this is the power wire that will turn on/off the rotor
brown->switched 12v+ this is the wire through which the regulator monitors battery voltage in the bike, and decides to turn on/off the rotor.
So long as its wired as listed above it should work.
I had the RR Green connected to the old regulator White (from the Grn/Blk/White combo of wires). Is that the same as "field coil"?
Offline calj737
  • I refuse...
« Reply #619 on: November 13, 2015, 12:03:51 PM »
Yes.
So I see it this way:
Electrosoport           Stock
WHT                         Yellow
WHT                         Yellow
WHT                         Yellow
BLK                          Green
GRN                          White
BRN                          Switched 12v
RED                          Battery POS
Offline minimo
« Reply #620 on: November 13, 2015, 02:47:47 PM »
I'm gunnin' to get this bad boy back out again.
Following up, ElectroSport replied to my question re: RR Grn to old reg White:
Yes, that should be correct.  Assuming the white wire has not been modified, that is the OEM wire that carries current into the rotor.
Wiring, for the most part on my bike is stock so that should do it. Still not clear on the recent adaptation of RR Brown to Ignition Blk...
Offline calj737
  • I refuse...
« Reply #621 on: November 13, 2015, 03:05:02 PM »
The BLK from the key switch provides the RR a reading of the "switched 12v" status as it is supplied from the battery. Follow this:
Battery POS has a red wire that goes to fuse block. Then passes thru Main fuse, then runs to key. This RED is always hot. When you rotate the key, the BLK, BR and BR/WHY at the key are now hot (switched). The RR wants to detect the "draw" your system is pulling so it can replenish the battery (via RED from the RR wired to POS). If the BLK shows less than a full charge, the RR pushes voltage to it. If the battery is fully charged, the RR basically stops throwing voltage to avoid overcharging. Hence the term Rectify and Regulate.
Simple enough, huh?
So whether you use BLK, BR or BR/WHT from the key, they all are switched at the key and show a status of the battery.
Offline minimo
« Reply #622 on: November 13, 2015, 03:33:32 PM »
Simple enough maybe even for me.
Thanks for following through on this with me, calj737!
Offline minimo
« Reply #623 on: November 16, 2015, 02:20:42 PM »
Yes.
Electrosoport           Stock
WHT                         Yellow
WHT                         Yellow
WHT                         Yellow
BLK                          Green
GRN                          White
BRN                          Switched 12v
RED                          Battery POS
I received a confirmation from ElectroSport that this is correct
Offline minimo
« Reply #624 on: November 18, 2015, 10:39:45 PM »
Be careful of what you order via eBay...
The spirit animal has gotta go, unfortunately, and I have a feeling it's going to uncover some bondo patch jobs. Can't wait to soda blast this bad boy
Is there an easy way to pop the gas cover? I doubt that my key will work to open it. Will I have to drill out the key hole?
« Last Edit: November 19, 2015, 09:25:14 PM by minimo »
