Author Topic: K7 Keihin carbs on K5?  (Read 1790 times)
Offline nitsua93
« on: November 18, 2012, 08:27:14 PM »
The only set of carbs I have are the K7 Keihins, which people seem to not like very much. Am I fine to use them with my K5?
Also, would it be beneficial to use K7 head,valves, and cam on a K5? Thanks!
Re: K7 Keihin carbs on K5?
« Reply #1 on: November 18, 2012, 08:39:49 PM »
I've thought about trying 'em for the accelerator pump advantage but I don't think the needles are adjustable on those, which might make them difficult to tune for a non-stock combination.  I don't think there is any advantage to using the cylinder heads or cams either.
Offline 750K
« Reply #2 on: November 18, 2012, 09:24:02 PM »
77 PD41 carbs have the adjustable needles, the 78 PD42 have the non adjustable needles. Which means you need to shim them instead, I know you'll need different intake boots as the round top carbs and PD's use different carb to motor boots.
77 Cb750, 78 Kz1000
Offline nitsua93
« Reply #3 on: November 23, 2012, 06:18:24 AM »
I did a dry fit with the 77 boots and they seemed like they'll fit. I need to boil them and try again. These, I believe, do not have the accelerator pump. Not %100 sure though.
Sent from my HTC One X using Tapatalk 2
bollingball
« Reply #4 on: November 23, 2012, 09:58:29 AM »
If they are 77 they have the pump. It will be on the # 2 carb look at the bowl it will look different. You might be able to see it a little on this pick. 77-78 look alike on the outside. They are some times called keyhole tops.
Ken
Offline nitsua93
Re: Re: K7 Keihin carbs on K5?
« Reply #5 on: November 23, 2012, 01:46:59 PM »
Ken
Ah, I wondered what exactly that was. The screws were too rusty for me to take the top off of that part during inspection.
« Reply #6 on: November 23, 2012, 03:11:36 PM »
Bollingboll - that's an interesting rack you have for your carbs. Any specific use for it?
bollingball
« Reply #7 on: November 23, 2012, 06:55:39 PM »
I find it easy to hold them in the angle I need when checking floats and a few other things. Just frees up the hands. I just C-clamp it to the bench when I need it. Just old scrap 2x4s the rack pivots then I lock it down
Ken
« Last Edit: November 23, 2012, 06:58:11 PM by bollingball »
« Reply #8 on: November 23, 2012, 07:33:47 PM »
Ken
Great idea.  I may copy it....
