Author Topic: 78 750F head  (Read 795 times)
Offline KRONUS0100
  • MAD MATT THE MANIAC
78 750F head
« on: November 19, 2012, 10:19:56 AM »
dangit.  my almost no mileage 78 F motor has given me an issue.  as the head was off the motor when i got it, it appears to not be the head that goes to the motor.  Exhaust valve guides got at least .080 wiggle in them.  looks like goona be ordering the hi po kit from Ken at Cyclex.......................................as soon as i'm not spending money on livestock.
MATT
Offline phil71
Re: 78 750F head
« Reply #1 on: November 19, 2012, 10:25:36 AM »
Why do you think that it doesn't belong on that block. Certain year F motors had notoriously crappy guides.. Search the forum and you can find out what years that was true.. Or someone with a better memory will chime in.
Offline KRONUS0100
Re: 78 750F head
« Reply #2 on: November 19, 2012, 12:04:54 PM »
no way guides wore that bad in under 15 miles, like i said almost no mileage motor.
MATT
Offline ZanVooden
  • I don't need no stinkin' title
  • This was suppose to be a quick one month job...
Re: 78 750F head
« Reply #3 on: November 19, 2012, 12:52:16 PM »
The 78F heads are know for bad guide wear. From what I've been told they normally need to be replaced between 20 and 30k miles.
I just replaced mine. The exhaust side guides were easily visibly worn. The holes were significantly oblong.
Modern guides hold up much better from what I understand.
From what I've read the reason for this was Honda trying to keep up with the DOHC engines and increased the valve size. The larger valves were at a slightly different angle to accommodate and created significant wear on the guides.
Offline ZanVooden
Re: 78 750F head
« Reply #4 on: November 19, 2012, 12:54:58 PM »
Nevermind, I just read your engine only has 15 miles on it.
So was the head reworked before you put it together and 15miles later you took it apart?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 78 750F head
« Reply #5 on: November 19, 2012, 01:41:07 PM »
So the P.O. drove it for 15 miles then took the head back off? Me thinks there is more to the story...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline madScientist
Re: 78 750F head
« Reply #6 on: November 19, 2012, 03:35:46 PM »
Sounds like either a new speedometer was put on in the VERY recent past or the speedo cable was unhooked most of it's life.
As for the head, mine had 12k miles on it and the guides were noticeably oblong.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline Thousandson
  • Ride, Fix, Repeat
Re: 78 750F head
« Reply #7 on: November 19, 2012, 05:15:56 PM »
Would the best answer be? Replace the valve guides. My motor is in pieces, I'm doing a full rebuild. I was thinking of leaving that off the list, but hearing this I should def measure my guides.
Current ride: 78' Cb750F
Re: 78 750F head
« Reply #8 on: November 19, 2012, 06:20:20 PM »
You've got the engine apart anyway...why not do it? Added reliability = peace of mind.
78 cb750f
83 KZ1100ltd
76 GL1000
77 cb750A (sold)
74 cb125s (sold)
Offline KRONUS0100
Re: 78 750F head
« Reply #9 on: November 20, 2012, 08:41:58 AM »
this is the motor that the original owner was killed on his way hoe.  the dealership that sold it took motor out and set it ion corner of shop.   a guy i know aquired the motor and all paperwork and it sat in his shop and had parts taken from it over the years.  I think at some point the relatively new head from this motor was put on another bike and its head was put with this motor.  I am in the process of putting this motor back together with new rings,seals,gaskets.....and now looks like new guides and possibly a couple valves.
MATT
Offline phil71
Re: 78 750F head
« Reply #10 on: November 20, 2012, 01:17:59 PM »
 To change a head on the SOHC 750, you have to pull it from the frame. If someone was going to pillage the head for an OLD MOTOR, wouldn't they just put the whole low mile engine in that bike? Doesn't make sense
