Author Topic: 70' ko project  (Read 3130 times)
Offline slyguy
70' ko project
« on: November 19, 2012, 12:00:29 PM »
Hi folks..got a 70' ko original showing 7k but in very rough shape..:(. I disassembled all but engine this past weekend but when degreasing frame today I found a rotted weak spot..:(
Re: 70' ko project
« Reply #1 on: November 19, 2012, 01:56:54 PM »
Looks like freeze damage..
Offline slyguy
Re: 70' ko project
« Reply #2 on: November 19, 2012, 05:27:56 PM »
yea, I have no idea? maybe it got water in the frame and then froze? now that you mention that, it is mushroomed up and does appear like a copper pipe might look after such a burst. My nephew in law is a welder, maybe he can weld it shut?
Re: 70' ko project
« Reply #3 on: November 19, 2012, 05:32:06 PM »
I would find a new frame. Welding will probably require a sleve over this spot. The hole is just a part of a whole week section, welding it shot will only postpone the problem.
Re: 70' ko project
« Reply #4 on: November 19, 2012, 06:10:35 PM »
I would have a good welder repair it.....subscribed.
Offline slyguy
Re: 70' ko project
« Reply #5 on: November 20, 2012, 04:26:45 PM »
Today I got my carbs cleaned up and ready for overhaul kits and I also need 1 float. I figure since money is very tight, I'll get some of the cleaning work done which usually gets rushed so a win/win for me:) not sure if I should paint carbs/polish bowls or what. Glad there's no rush. Lol!
Re: 70' ko project
« Reply #6 on: November 20, 2012, 04:41:06 PM »
Is the float missing? I soldered leaky one sucessfully.
Offline slyguy
Re: 70' ko project
« Reply #7 on: November 20, 2012, 08:22:24 PM »
no not missing, in fact the last carb/float even floated but had fluid inside so I'll be replacing 2 of them. I also need 1 gasket for the vacuum port screw and also the plate that connects all 4 carbs together, mine was cracked & previously epoxied which failed on disassembly.
Offline Tews19
  • I am no
Re: 70' ko project
« Reply #8 on: November 20, 2012, 08:25:35 PM »
Should be a nice project. For any pics before the tear down? We all love pics!
1970 Honda CB750 survivor.
Offline slyguy
Re: 70' ko project
« Reply #9 on: November 20, 2012, 08:42:23 PM »
naw I forgot:( this is when I thought to get my camera...
Offline Garystratos201
  • I have never been a
Re: 70' ko project
« Reply #10 on: November 21, 2012, 11:54:29 AM »
I vote for mig welding, you`ll be able to tell if its too rusty when they try to weld it. Im in for this one also...Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline Magpie
Re: 70' ko project
« Reply #11 on: November 21, 2012, 01:47:08 PM »
I'm in, I love to watch! ;D Cliff.
Offline lucky
Re: 70' ko project
« Reply #12 on: November 25, 2012, 05:49:44 PM »
Good welders do NOT weld rusty metal.
A good welder would cut out that rusted section and find out what is going on because
the tubing is only .062 thickness. You will need to find out how much corrosion is going on. I would start by sanding the outside of the tube, (NOT GRINDING), and find out if the metal is corroded all the way through.
Then use a die grinder to clean the edges of the slot.
It is possible if the metal is good that a small patch can be TIG welded into that area.
By the way I would get the entire frame grit blasted and phosphate dipped to stop all the corrosion. You could just use phosphoric acid on it and then give it a good rinse. Dry and paint within 4 hours.
Re: 70' ko project
« Reply #13 on: November 26, 2012, 07:31:59 AM »
Sorry Lucky I am aware that you do NOT weld rusty metal and that a patch has to be made. I  have been in the Collision repair industry for 43 years. I didnt list the steps because i figured that is was a given...............Gary
« Last Edit: November 26, 2012, 12:07:27 PM by Garystratos201 »
Offline slyguy
Re: 70' ko project
« Reply #14 on: November 26, 2012, 10:32:15 AM »
Thanks guys for the tips! I took it over to my nephew in law who's a good knowledgeable welder and plan to pick it up in a week or so. Geez, I just finished going thru Mark's sandcast #97 thread..Whoa! and after reading alot of your threads I've been just doing some light cleanup of everything and moving it indoors for long storage. I just don't have the bucks available right now to do it right. I'm thinking it might be nice to at least go thru the engine this winter, Is it best to try to find nos gasket sets/seals or what?
Offline slyguy
Re: 70' ko project
« Reply #15 on: November 27, 2012, 07:18:11 PM »
how do you guys go about the grubby battery box? :)
Re: 70' ko project
« Reply #16 on: November 27, 2012, 08:53:15 PM »
Ideally, sand blast and powder coat.
Offline hoodellyhoo
  • CB350F
Re: 70' ko project
« Reply #17 on: November 28, 2012, 04:45:29 AM »
just be VERY careful when removing the rubber bits. They can tear easily.
Offline slyguy
Re: 70' ko project
« Reply #18 on: December 02, 2012, 07:18:52 PM »
I picked up my frame all fixed/welded:) and also got my "broken in 2 pcs" carbs plate welded this past week too. It's gettin cold rainy & even snow now..:( making media blasting difficult but I'm getting setup for that hopefully soon. Still need to look into that phosphate acid deal too, sounds good but I'm thinking of rattle canning myself which would need to wait till spring/summer/warmtime..lol!
Re: 70' ko project
« Reply #19 on: December 03, 2012, 12:36:51 PM »
There was a group of frames that did not have weep holes in the bottom rails. They would collect water from up above, condensation and the like and end up with those freeze/burst/rust problems. Since you got it fixed, you should now drill the weep holes that the factory began drilling. I'll do a search for you. I know Honda Man has the location and diameter.
Re: 70' ko project
« Reply #20 on: December 03, 2012, 12:38:39 PM »
Here's a thread on the subject. I searched on "frame drain holes". You can search further i got a lot of hits.
http://forums.sohc4.net/index.php?topic=105884.5;wap2
Here's another. The last pot in the thread is from HondaMan.
http://forums.sohc4.net/index.php?topic=109165.0
« Last Edit: December 03, 2012, 12:40:57 PM by MCRider »
Offline slyguy
Re: 70' ko project
« Reply #21 on: December 05, 2012, 04:46:21 PM »
Wow cool! Thanks MCRider!
Offline slyguy
Re: 70' ko project
« Reply #22 on: November 17, 2013, 03:44:16 PM »
Geez, I haven't gotten much done...in a year! lol... Got a warm spell this weekend so I got out the pressure washer & cleaned up a couple sets of cases:) I had forgotten what tedious work it is scraping gaskets & cleaning motorcycles engines... I'm still wondering what to do with my output shaft/bearing. I could just reuse or...my old timer friend who use to run a repair shop for all bikes back in the early 70's and also specialized with building these for the street says to install the dbl row bearing but I think I would need another shaft too(outta a k2-k3?) but I won't be doing hole-shots or anything anyways.
