Author Topic: spark from ignition lead to cylinder head  (Read 1286 times)
Offline Kyytsis
« on: November 20, 2012, 04:22:41 AM »
I noticed today in damp weather that no1 spark lead is making a spark to cylinder head... Time to change leads or something else at the seme time?
For CB 750 K7 what to look for? When I had Aprilia Futura RST1000 I used leads from an Fiat Marea :)
Ville
Offline MoMo
  • Ride like you're invisible
Re: spark from ignition lead to cylinder head
« Reply #1 on: November 20, 2012, 04:40:59 AM »
Leads can  be changed but not without difficulty.  There are a couple how to threads on this forum- easiest way is to find replacement coils.  Also, there is insulated sleeving available that you could slip over the wires...Larry
« Reply #2 on: November 20, 2012, 09:40:41 AM »
Between this and caps going bad plus the want for hotter spark many of us just buy new aftermarket coils like Dyna. If you do this keep in mind that coils with less resistance will fire a hotter spark but at the cost of using more voltage and could affect the voltage in your system creating charging issues if you have 30-40 year old bullet connectors that are loose or corroded.
You can replace the wires in stock coils but you need a Dremel to cut into the coil around the lead and epoxy to seal it again when you put on new wires. So you will need to buy a Dremel, plug wires and in all likelihood new caps. Are new coils looking any better now?
With that being said I believe it is NGK that makes a splice connector you might be able to use. If you were to go this route you'd best check the resistance in your caps to see if the fire is getting through them properly. I'd be really surprised that your caps are up to specs if your wires are shot.
6 of one and a half dozen of the other.
« Reply #3 on: November 20, 2012, 10:04:19 AM »
+1 for splicing fresh wires and caps.
Online dave500
« Reply #4 on: November 20, 2012, 12:01:33 PM »
just do the caps first thatll probably fix it,wipe the wires over with turps to remove the years old crud.
Offline Kyytsis
« Reply #5 on: November 22, 2012, 01:21:40 AM »
Ok, cheers!
