Author Topic: cb550K Battery issues and Carb/idle issues  (Read 759 times)
Offline l2edken
« on: November 20, 2012, 03:43:44 PM »
Sup guys, trying to fix a problem ive been having every once and a while randomly... Bought a new battery, AGM type, works great sometimes. Randomly sometimes though, i lose all battery power. 2 weeks ago i had a serious issue with battery drain so i stripped down the entire harness and clean all connectors and made sure there were no frayed or split wires. Also found that my rectifier wasnt grounded properly so i fixed that. Bike was fine until just today. Riding home from work i noticed my headlight was a little dim, still have great power on the bike though. Stopped and bought some gas, kicked it over and it fired right up. However when i took off i made it about 20 feet and it died and i couldnt get it started again. Almost no power, even my LED brake light wouldnt turn on. Got my dad to jump me and i got it home and now here i am.
Things ive done: Watched voltage at around 4/5K and it steadily rose, so i believe my stator is still good.
                           Checked my Rectifier and that had correct ohm readings off of the yellow and the red.
Secondly, a problem ive had for a while which has never been solved. My carbs! Ive got a 78 550K with those dang PD carbs. The bike is contantly hunting for idle. Ill start it up and letting it warm with choke on and when i turn it off, it usually revs up. Ill turn the idle knob down and it will almost bog then start to level out around 1500. Ill twist the throttle and it will hang at around 3/4k until i turn the idle knob back down some more. This goes on for the entire warm up cycle. When i finally find an OK idle speed to take off ill set off on my journey. Bike will run perfect throughout the entire trip but anytime i come to a stop and either clutch or neutral, i can hear my idle is way back up there, like around 3/4k again. Ill lower it back down and take off, again bikes running fine, but when i stop later, itll be the same thing, way high. I can never achieve a consistent and even idle, even around 1500. Its ALWAYS hunting for idle. Up down bog rev never even remotely level.
Background: rebuilt top end, 4-1 exhaust (open, no muffler), pods ( i know this is prolly half my problem ) Stock pilots, mains are either 108 or 110, cant remember, i think 108 (mains are great, no loss of power from idle all the way to redline) . Air mixture is 2 turns out.
Any suggestions would be great! thanks guys!
Re: cb550K Battery issues and Carb/idle issues
« Reply #1 on: November 20, 2012, 05:13:02 PM »
PD carbs don't have an air bleed screw adjust.  They have an Idle mixture screw.  And function backwards from and air bleed screw.
I saw no carb vacuum balance in your list of attended items.  If you want consistent idle, this is must.  (As well as a prior and entire 3k tune up check list completed.)
As for the charging system, you only reported checking half of the rectifier.  You also mentioned no electrical changes from stock. Coils/ignition trigger and lighting changes can all have an effect on power available and the charging system's ability to maintain a battery.
What follows is a re-post of a checking procedure I use:
Charging system methodical verification checks, CB750, CB550, CB500, CB400, and CB350.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
C -- Repeat the measurements of B with lighting off.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
I - (not used, can be confused with L)
J -  The only parts that remain to prove or expose are the REGULATOR (in active mode) and the electrical path between the battery POS terminal and the black wire that connects to the REGULATOR.
K - Lying to and starving the regulator
The regulator can only do its job correctly if it gets a proper voltage report of true battery voltage status.  The Vreg monitors the Black wire for this status.  Measuring the voltage lost between the Battery terminals and the Vreg connections identifies problems that are not really the charging system's fault.
Two connection paths must be checked, the Battery POS terminal to the Black wire connection at the VReg, and the Battery NEG terminal to the Green wire connection to the Vreg.  A volt meter can measure these losses directly by placing a probe between the two identified points, Black path and then the green path.  The numbers are summed and the error seen by the Vreg quantified.  Anything over .5V loss is cause for concern and anything over 1V is a certain issue to be corrected.  Each connector, terminal, fuse clip, or switch in the pathway can cause voltage reporting loss.
The regulator also passes the received voltage on to to the Alternator field coil to create a magnetic field within the alternator,  The voltage level determines the strength of the magnetic field and the maximum output capability of the alternator.  Therefore, starving  the Vreg of true battery voltage leads to reduced max output capability of the alternator.
L - regulator operation/verification.
  The Vreg sends voltage to the alternator field in response to measured voltage which is battery state of charge.  Any voltage at the battery of less than 13.5V sends full black wire voltage to the alternator's white wire.  The alternator output will vary with RPM, even if "told" to produce max power by the Vreg.  If the alternator has enough RPM to overcome system load, any excess power is routed to the battery which will raise the battery voltage (slowly if depleted and rapidly if nearly full).   When the battery reaches 14.5V, the regulator reduces the voltage to the alternator, reducing output strength and preventing battery overcharge.  If the battery exceeds 14.7V, the regulator clamps the alternator field coil power to zero (0V), effective shutting off the alternator.
Because, there is electrical load from the system, an alternator that is not producing power allows the battery to deplete and the voltage falls.  The Vreg responds by turning the alternator back on in accordance with battery state/ charge level.
The Vreg state changes can be monitored/verified by observing the battery voltage state, and the White wire to the alternator field.  (Two meters are handy for this.)  The "trip" voltages can be adjusted with the adjust screw, while changing engine RPM and electrical load that the bike presents to the battery/charging system to "make" the battery reach the voltage levels need for the set trip points.  IE. with load reduced (lighting off) and the engine above 2500 RPM, a charged battery will attain 14.5 V.  Anything above that and the adjust screw needs to be backed out to keep the battery safe from harm.
The shop manual outlines bench set up mechanical adjustments that should be performed on unknown or tampered units.  These should be resolved before final trip point adjust tuning.
Note that while the system is working, the Vreg can change states rapidly before your very eyes., changing 5 times or more while you blink.  Therefore, you may have to mentally average values measured on the White wire if your selected meter doesn't do that for you.
Offline l2edken
« Reply #2 on: November 20, 2012, 10:12:20 PM »
0.0 wow thank you!!! looks like i have a busy weekend!
Offline harisuluv
« Reply #3 on: November 20, 2012, 10:24:21 PM »
Twotired that was as sexy post.
Offline XLerate
« Reply #4 on: November 21, 2012, 12:18:23 PM »
Downright gorgeous!
One other item, take a peek under the insulation of battery cables and at wire connectors, looking for any sign of green corrosion. Sometimes that plastic covering completely hides the fact that the entire cable or wire has corrosion all over itself, under the plastic. Good idea if possibly to replace battery cables with fine wired welding cable, I think it's 6 gauge?
