Author Topic: 1975 CB 750 negative battery cable connections? where?  (Read 849 times)
Offline electros
« on: November 20, 2012, 04:35:50 PM »
Where on the bike will the negative side of the cable connect?   want to keep the bike stock- any pictures or info will help-
thanks
Re: 1975 CB 750 negative battery cable connections? where?
« Reply #1 on: November 20, 2012, 04:43:46 PM »
Mine is to the engine mounting bolt on the left - the one right under the side cover.
Offline electros
« Reply #2 on: November 20, 2012, 04:47:39 PM »
any chance to send me a picture of that?
thanks
Online CycleRanger
  • No comment about being an
« Reply #3 on: November 20, 2012, 04:53:22 PM »
Here ya' go.  Ground goes to the upper rear engine mount.
Offline electros
« Reply #4 on: November 20, 2012, 05:22:55 PM »
I thought I had the correct cable but maybe not-how long would you say that cable is?  I think mine is like 8-10 icnhes?
Offline electros
« Reply #5 on: November 21, 2012, 08:39:46 AM »
The cable I had was correct!!!!!!!!!  Thank you baby Jesus!!!!!!!!!!-it was just mounted wrong and was attached to the tool tray bolt-it tool like 3 minutes to take out that engine bolt and thread the cable down through the frame and that 12" cable fit like a glove- thanks for all the info!!
Offline bjbuchanan
« Reply #6 on: November 21, 2012, 08:41:15 AM »
That sounds about right its not very long. IIRC theres only rly one way to run it up to the battery so its long enough
