Someone put alot of effort into this thing,started out as a 76 Fmodel, the welds on the swingarm extension are top notch,for some reason he added 2 struts per side, looks like an 82-84 Nighthawk front end which looks great actually except for bent tubes, unknown rear wheel, the rear tire is only a 130/90, KZ tail piece . BUT, it got smacked super hard and probably ran over ! The Kerker is smashed flat , it broke the cases at the ignition area very badly. The good part and sorta weird is that the carbs are nearly spotless on the inside and it's got #140 mains in them ! The engine kicks over great,very strong compression, will know more when we look inside ! There is no reinforcement on the valve cover(which is also smashed and cracked) like what was common on big bore jobs. The big jets leave me to believe its not a stock engine . We will pull it out soon to see exactly what's there!
My buddy , Old Ned , picked it up for cheap, $175.00 , I believe , hope it will be worth that !
