Setup info:
I have a stock (with the exception of motogp werks exhaust) 1975 cb550k running 022a carbs with the stock idle jet (I've seen conflicting reports of 38's and 40's being stock, all I know is it's stock) and a 105 main. Idle air screws are 1 turn out and the needle clips are stock. I'm running the stock airbox with the standard filter (a little dirty but not bad). The floats are all within a mm of each other and I've done the tappets and cam chain adjustments. I also checked the timing, points gap, advance springs and all that, it's good. Stock coils, wires, and plug caps too.
What it's running like now:
I've got all the above settings (stock with the exception of a motogp werks exhaust, a 105 main jet and the IAS 1 turn out) and the attached pictures are after a 1/4 throttle plug chop and a full throttle plug chop respectively. It was about 50 deg. f when I did these runs and these are D7EA NGK's.
It's not stumbling anywhere and just by feel, other than a slight burble on hard off throttle deceleration (lean condition I'm pretty sure) you wouldn't say anything out of the ordinary about how it's running. This slight burble on hard off throttle decel can be cured by adding in like 30% choke if that gives you all some indication.
Do these plugs look acceptable or too lean? Any suggestions for what (if anything) needs to be changed?
