Author Topic: Rear wheel bearings  (Read 827 times)
bollingball
Rear wheel bearings
« on: November 22, 2012, 06:23:12 PM »
1978 750K
What is the best price anyone has found for the All Balls kit. Three bearings and a seal. Why do you need the seal if you go with double seal bearings? To keep crap out not grease in?
Ken
bollingball
Re: Rear wheel bearings
« Reply #1 on: November 22, 2012, 06:54:56 PM »
I also wonder who the manufacture is of the all balls bearing?? Anyone ever look for a name on the bearing ??
Ken
« Reply #2 on: November 22, 2012, 06:56:27 PM »
That's interesting that it has the seal in the kit! I haven't seen those since the 1980s. Maybe I should get one: mine is all cracked and split. It's there to keep grit out, because the OEM bearings were only sealed on one side, and the sprocket bearings wear the fastest - maybe because grit gets in behind them?
My local bearing house gets between $7.50 and $9 for those size bearings in 2 seals, so other than the added shipping, that doesn't seem too bad at $28?
« Reply #3 on: November 22, 2012, 06:57:47 PM »
Ken
The steering bearings are KML. I researched them a few years ago: they are made in the Netherlands area, with hard steels. I don't know about the wheel bearings, though?
« Reply #4 on: November 22, 2012, 08:50:14 PM »
Powersportsjunkie has them for $24.30...
Kit #25-1362
Offline Apexxn
« Reply #5 on: November 23, 2012, 05:11:39 PM »
I looked at some wheel bearings from All Balls for a RD I was doing they were made in China.
