Author Topic: CB750 K3F - AKA The Red  (Read 118557 times)
Offline MoMo
  • Ride like you're invisible
Re: CB750 K3F
« Reply #125 on: December 10, 2013, 06:46:44 AM »
Just saw this thread Prokop, very interesting-like your Yankee/Czech ingenuity.
On the bushings,  there were two styles-one with a collar and the other recessed, not sure which style mated to which model.  My 75 Red Rider called for the collar type but I installed the other style, worked well.
Nice work, will be following...Larry
Re: CB750 K3F
« Reply #126 on: December 10, 2013, 06:53:34 AM »
Thank you, Larry  :)
Re: CB750 K3F
« Reply #127 on: December 11, 2013, 04:37:54 PM »
I don't recall ever seeing anyone doing a meld of F and K bikes here before; should be interesting. :)
Been done several times, it's called an F'nK
Re: CB750 K3F
« Reply #128 on: December 12, 2013, 03:08:05 AM »
I prefer K3Fka - kefka means toothbrush in Slovak :)
Re: CB750 K3F
« Reply #129 on: January 14, 2014, 02:12:11 AM »
I am halfway through cutting and laping valve seats - 3 and 4 are finished and mechanic's blue shows nice imprint.
Offline MoMo
Re: CB750 K3F
« Reply #130 on: January 14, 2014, 02:52:28 AM »
Why not A Kafka?  ::) ...Larry
Re: CB750 K3F
« Reply #131 on: January 14, 2014, 03:26:43 AM »
Oh, that's a good one, Larry.   ;D
Re: CB750 K3F
« Reply #132 on: January 14, 2014, 03:28:05 AM »
And Kafka or kavka means Western Jackdaw - http://en.wikipedia.org/wiki/Western_Jackdaw, LOL.
Offline MoMo
Re: CB750 K3F
« Reply #133 on: January 14, 2014, 05:02:22 AM »
Actually, I was referring to Franz Kafka Prokop.   Larry
Re: CB750 K3F
« Reply #134 on: January 14, 2014, 05:14:53 AM »
Yes, I know, just can't imagine styling a motorcycle like The Trial
Re: CB750 K3F
« Reply #135 on: January 14, 2014, 06:05:20 PM »
Cutting seats.
Offline edwardmorris
  • Youngish
Re: CB750 K3F
« Reply #136 on: January 14, 2014, 08:20:10 PM »
The 60s? Or all three? Looks cleeeeen :)
Re: CB750 K3F
« Reply #137 on: January 15, 2014, 03:25:01 AM »
I did all three.
  • Youngish
Re: CB750 K3F
« Reply #138 on: January 15, 2014, 08:44:48 AM »
Very nice! I'm sure you're happy with the oil stay tests now. Are you going to be doing any porting? Would love to see someone experienced do it first before I attempt it ;) After cleaning out some of that carbon gunk, my ports look horrid, palgued with casting pimples and irregularities. I've been keeping an eye on the porting tests thread in the performance forum, but I only wish to clean mine to keep the carbon from gunking it up again. Any gains will be just a nice bonus :)
Re: CB750 K3F
« Reply #139 on: January 15, 2014, 08:55:03 AM »
I found out that the 45 deg sealing surface has to be limited from the top and the bottom.  Had to spent hundred more on tools, but it is worth it IMO.
Porting - good question, I am still thinking about that one.  Most likely I will compare the head with Hondaman book pictures and decide what can be done.
I did some head smoothing and cleaning on 4.2 jeep engine back in the day, but I don't think it made much of a difference.
Re: CB750 K3F
« Reply #140 on: January 15, 2014, 10:12:18 AM »
Hondaman is a big fan of porting the 750 head, to remove many of the obstructions resulting from sloppy casting.
Re: CB750 K3F
« Reply #141 on: January 16, 2014, 02:08:43 PM »
Machinist's blue imprint after lapping.
Offline bjbuchanan
Re: CB750 K3F
« Reply #142 on: January 16, 2014, 07:12:22 PM »
Morris
You don't have to go wild with the porting, just clean up the real rough bumps and lumps. There are threads out there on it, homebrew porting, DIY, they have some really good pics
70
The flange style should replace everything but the plastic end cap if the bike has the end cap. If it has it I believe it is utilized. It is hard to nail specifics, kinda like how everybody has done a different steering head bearing stack
Re: CB750 K3F
« Reply #143 on: January 17, 2014, 03:51:28 AM »
I am afraid I don't follow, what flange and cap?
Re: CB750 K3F
« Reply #144 on: January 27, 2014, 06:34:02 PM »
Installed one inner spring to measure spring installed height. I need a compass, none of my methods is reliable enough.
Offline rtbmrgl
  • Got Points! Roseville, Ca
Re: CB750 K3F
« Reply #145 on: January 27, 2014, 08:02:10 PM »
New fuse box rewired to the old plug.
That's a good idea, my fuse box is corroded, I was going to clean it up but this is a better fix.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Re: CB750 K3F
« Reply #146 on: January 28, 2014, 02:56:28 AM »
Offered also by Hondaman:
http://sohc4shop.com/catalog/product_info.php?manufacturers_id=12&products_id=48&osCsid=5510e6252a4b462022769ece21b177ee
The fuse box itself I had to buy on e_bay, impossible to buy locally.
Offline rtbmrgl
Re: CB750 K3F
« Reply #147 on: January 28, 2014, 07:23:02 PM »
thanks for the info!
thanks, Mark
Roseville, Ca
Got Points!
Re: CB750 K3F
« Reply #148 on: February 04, 2014, 03:23:19 PM »
Installed all inner springs to check installed height.
Offline rtbmrgl
Re: CB750 K3F
« Reply #149 on: February 05, 2014, 02:21:49 PM »
70CB750, Whats the outcome of the spring height after cutting the seats, is it close to stock or do you need to add shims?
thanks, Mark
Roseville, Ca
Got Points!
