Author Topic: Mini gauges on a 500 - anyone use them? Tach fit issue.  (Read 1360 times)
Offline Chachi
« on: November 24, 2012, 12:25:37 PM »
I have a set of 2.5" chrome mini gauges on my 500. My stock gauge faceplates looked horrible and I opted not to disassemble them to re-do their faceplates. I mounted the mini gauges straight to the triple and the speedo seems to be ok - mounts nice and straight. The tach, however, does not. I forced it to be nice and straight which put too much stress on the tach cable and subsequently broke the tip off. It went downhill from there... I ordered a new tach cable and then broke my tach cap assembly when removing the broken cable. Luckily, I have a new tach assembly on the way from another forum member. I can rotate the mini gauge out to the right to accommodate the cable, but I just don't like it. The fit issue is due to the headlight. The speedo side has a cutout to allow the lower mounted mini gauge, but the tach side does not. Anyone else using these gauges on a 500 and have any fitment ideas? I have stock 500 handlebars and headlight ears with no plans to change either. Thanks.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline srbakker
  • Spam & Eggs
Re: Mini gauges on a 500 - anyone use them? Tach fit issue.
« Reply #1 on: November 24, 2012, 12:31:12 PM »
Picture?
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline Chachi
« Reply #2 on: November 24, 2012, 12:39:06 PM »
Not sure if these help or not...
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
« Reply #3 on: November 24, 2012, 12:39:33 PM »
Tach cable not attached at the moment...
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Chachi
« Reply #4 on: November 24, 2012, 12:40:57 PM »
When I attach the tach cable I will probably have to rotate the gauge even further out (see pic #4).
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Lavis500
  • Why don't you go ask a
  • "Don't plan vast projects with half-vast ideas"
« Reply #5 on: November 24, 2012, 03:30:27 PM »
I've never used these, but it looks like you could either make a different mounting bracket OR get longer mounting bolts and place a spacer between the bracket and the triple tree for more clearance.  This'll give you more room to work with.
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
Offline bjbuchanan
« Reply #6 on: November 24, 2012, 06:16:57 PM »
I have the same gauges for my 750. You gotta atleast in your case tweak the brackets that comes with it or shim it and use(if need be) a longer bolt
Offline Chachi
« Reply #7 on: November 25, 2012, 07:32:53 AM »
Thanks. I was going to experiment with a spacer to give it more height off the triple. I had the same idea with different headlight ears and lowering the headlight, but I don't want to get into all of that just to mount these gauges how I'd like. There's also the option of turning out the speedo to the left the same amount the tach is to the right for symmetry... and my stock gauges work, the just look bad.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline srbakker
  • Spam & Eggs
« Reply #8 on: November 25, 2012, 08:23:33 AM »
I think I'd just look into cutting and bending a cleaner mount from a piece of aluminum sheet.
1975 CB750 K5
2007 Triumph Tiger
Offline Chachi
« Reply #9 on: November 25, 2012, 03:31:46 PM »
I added some 1/2" nylon spacers and I think I will be OK with it for a while like this. There are some nice mounts out there for these mini gauges, but they don't fit my triple. I may circle back to it once I resolve some of my other more important issues.
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-steering-parts-top-triple-tree-dual-mini-gauge-mount-console-87-995.html
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline lucky
« Reply #10 on: November 27, 2012, 06:31:19 AM »
The tach ratio must be selected for that motorcycle. Front wheel size and other factors.
Offline Chachi
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
