Author Topic: Is This Healthy????????  (Read 1342 times)
Offline RebelSkyRot
« on: November 25, 2012, 04:50:35 PM »
Installed a set of rings on one of my new pistons, is this amount of gap normal? Both the piston and rings are standard bore size btw
« Last Edit: November 25, 2012, 04:59:12 PM by RebelSkyRot »
Online CycleRanger
  • No comment about being an
Re: Is This Healthy????????
« Reply #1 on: November 25, 2012, 05:01:11 PM »
Did you check the gap with the rings in the bore?
Offline TS250
« Reply #2 on: November 25, 2012, 05:13:10 PM »
Rebel, the gap is the distance between the ends of the ring when it's in the bore, like CycleRanger said.  I don't know what you're trying to show us with your photo.
Check it like so:
« Last Edit: November 25, 2012, 05:17:25 PM by TS250 »
« Reply #3 on: November 25, 2012, 05:48:17 PM »
In the picture you showed the ring does look to big for the piston to me anyways.
Offline Xnavylfr
« Reply #4 on: November 26, 2012, 05:41:52 AM »
That ring looks OS on a STD piston.New rings are ALMOST scary to install without breaking 1 because they fit that tight!!!
Xnavylfr(CHUCK)
Offline RebelSkyRot
« Reply #5 on: November 26, 2012, 05:57:28 AM »
Hmmm well I'll have to check the gap once it's in the cylinder because both my pistons and rings claim they're std size
Offline Xnavylfr
« Reply #6 on: November 26, 2012, 10:40:23 AM »
You will have SOME slop side to side but I've never seen THAT much of a new ring pushed out to one side of the ring groove!!!
Just for general info if you didn't know, rings are marked for top  with a dot or small circle!!!  If you get them wrong that 4 stroke turns into a 2 stroke smoker real quick!!
Xnavylfr(CHUCK)
bollingball
« Reply #7 on: November 26, 2012, 05:37:09 PM »
I doubt you will get that ring in the bore. It looks to big.
Ken
Offline fastbroshi
  • Puppet
« Reply #8 on: November 26, 2012, 08:54:53 PM »
That pic looks to be a bit misleading.  Are you pushing the ring out from the other side?
Just call me Timmaaaaay!!!
Offline lucky
« Reply #9 on: November 27, 2012, 06:19:25 AM »
If you buy a set of rings and they are in a package that is wrapped, the rings are allready stacked properly, in the right order with the marks facing up.
If you take them out of the package and mix them up  then all bets are off.
Offline Xnavylfr
« Reply #10 on: November 27, 2012, 08:43:42 AM »
I looked at a STOCK piston with the second ring in place (#1 was broken) and if you push the ring into the groove from 180 degrees opposite the gap I measured a 5/16 gap and the complete width of the ring was OUT of the groove. Take a ring compressor and squeeze the ring down in the groove, each end of the ring should NOT touch each other. Place the ring in the bore as the other picture shows and measure the gap "The rings are serviceable if gap is .MM (.028 in)" from CB750 shop manual.
Xnavylfr(CHUCK)
