Author Topic: Need some non-Honda expertise!  (Read 2647 times)
« on: November 25, 2012, 05:51:45 PM »
Trying to get a disc brake arranged on my little CB125.
I need a master cylinder that is small, and maybe has a brake switch on it? The Kawis and Suzy's have some like this, wonder if any of y'all might know a particular one I could look for?
Otherwise, I'll be stuck with having to find a CB100 front wheel and drum brake. I'd like to stay with the 'cool' of the disc, if at all possible, tho...  :D
Re: Need some non-Honda expertise!
« Reply #1 on: November 25, 2012, 06:18:12 PM »
The little Suzuki GT185 had a front disc.Master should have a brake switch though they do get a little fragile with old age. Do you already have a rotor setup ?
Offline Goofaroo
  • general nuisance
« Reply #2 on: November 25, 2012, 06:57:40 PM »
My wife's 2008 Yamaha Vino 125 has a master cylinder that has a nice lever with a mechanical brake switch and a window in the reservoir. It also accepts the rear view mirror.     Here's one that's missing the lever for $36:
http://www.ebay.com/itm/04-09-YAMAHA-VINO-125-OEM-FRONT-BRAKE-MASTER-CYLINDER-RESERVOIR-COVER-CAP-4450-/110915613012?hash=item19d315f154&item=110915613012&pt=Motorcycles_Parts_Accessories&vxp=mtr
I just happened to have the Vino in the garage to look at but it looks like there might be some viable solutions in the scooter market. Pretty much all of the modern scooters have a front disc and I'm guessing they all have a brake switch. Also, the Vino has 7/8" bars FWIW.
1972 CB500 four
1972 CT90
1974 CT90
1978 BMW R100S
1983 CX500
1986 GL1200 Aspencade
1986 CH150 Elite Deluxe
1984 NH125 Aero
2005 Genuine Stella 2T
2007 KLR650
2002 KLR250
1985 XR350R plated
1994 DR350SE
2004 Concours ZG1000
1987 KDX200 C
1992 KDX200 E
2010 BMW F800GS
Always room for one more.
Online scottly
« Reply #3 on: November 25, 2012, 07:46:02 PM »
Check out the smaller dirt-bikes and quads, as well as the Chinese clones.
« Reply #4 on: November 25, 2012, 08:30:38 PM »
Yep, my little 125 has a front disc: it had a mechanical caliper. They weren't much when new, and all of them have now failed for the special bearing inside which falls apart with use. Others here have helped me muster a CB350F front caliper, which I now have mounted, but need a small master w/the switch so I don't add 5 lbs. of hose, junctions, reservoir, and fluid, to a 15 lb. front end(!).
« Last Edit: May 24, 2013, 09:55:30 AM by HondaMan »
« Reply #5 on: November 25, 2012, 08:33:49 PM »
That VINO thing looks close, has similar fittings, it seems. Thanks for the ideas, guys: I'll mosey past the scooter stores here and take a look-see!
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #6 on: November 25, 2012, 11:25:09 PM »
Keep in mind Yamaha uses left handed mirror threads on the right side.
At least they used to do so, worth a check before buying.
Offline Xnavylfr
« Reply #7 on: November 26, 2012, 10:44:29 AM »
YAMMIES still do. I've got a 2000 Roadstar .
Xnavylfr(CHUCK)
Offline Untold
« Reply #8 on: May 06, 2013, 06:22:48 AM »
Sorry to resurrect an old thread.  Any updates on this? I'm trying to find a replecement caliper for my 1975 CB125 with the mechanical disk brake.  Any caliper bolt right up? I dont' mind adding the hoses and master cylinder and all that jazz.
1976 CB550K
Offline tomkimberly
« Reply #9 on: May 23, 2013, 02:03:22 PM »
Has anyone considered adapting the front disk from a CR85?
Tom
Offline Old Scrambler
« Reply #10 on: May 24, 2013, 06:33:28 AM »
Quite a few low-mileage CB200T models around and they have the mechanical disk.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline tomkimberly
« Reply #11 on: May 24, 2013, 08:30:16 AM »
I think the question is what hydraulic system can be used to replace the mechanical system.
Tom
« Reply #12 on: May 24, 2013, 09:56:53 AM »
Tom
Yep, that's what I am attempting. It doesn't need a lot of hydraulic power, such a small bike.
Offline crazypj
  • I'm brill, me
« Reply #13 on: May 24, 2013, 08:30:12 PM »
I would use a banjo bolt switch, they ain't expensive
Did you need any specific bore size?
« Reply #14 on: May 24, 2013, 10:22:16 PM »
There's a good idea! I didn't know they existed? I'll have to measure the hose fittings, don't know the size offhand.
Offline crazypj
  • I'm brill, me
« Reply #16 on: May 25, 2013, 10:01:51 AM »
Really there are only two sizes, 10x1.00mm and 10x1.25mm
Pretty sure you wouldn't use an inch size m/c they are mostly HD and much larger
I've used a couple of Suzuki RM motocross ones, very small but only 11mm bore
Offline andrewk
  • doin' it.
« Reply #17 on: May 29, 2013, 01:21:12 AM »
Keep it all Honda, man!
ATC200 master cylinder will work, MB5 too, but that's a harder bike to find parts for.
Chinese jobs go for under 20 (plus ship) on ebay, and include a brake light switch.  Can't speak for the quality, obviously, but fwiw, I have had good luck with cheap MC's lately.  Fit and finish looks decent enough.
I'm using an MB5 unit on my C100-  works good enough, certainly better than those nasty cable operated ones.
Hope this helps!
