Author Topic: A couple different cam grinds...  (Read 5965 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« on: November 26, 2012, 05:24:34 PM »
While prepping a spare engine to replace another troublesome mill, I came across this unusual grind profile on one of the bearing journals...
At what "degree" does the cam bearing journal start to melt?
Turns out one of the oil orifices (that little oil-jet orifice in the top of the head, under the cam tower) was plugged with an amber-like material about the size of a small grain of sand. DAMN!
Now for the other grind...
While sifting through my assortment of cams I discovered that one of these is not like the others!
Look at the plateau on top of the lobe! Now I have to scrounge up a dial gauge and figure out how big those bumps are!
« Last Edit: November 27, 2012, 03:50:48 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Re: A couple different cam grinds...
« Reply #1 on: November 26, 2012, 07:06:59 PM »
Plateau?!  That's a new one for me.
« Reply #2 on: November 26, 2012, 07:15:49 PM »
 Get that washer off the end look for markings.. dibs if you are selling it,...
