Author Topic: CB750K4 stock carb clamps - loose  (Read 971 times)
Offline h2yamyk
« on: November 28, 2012, 11:16:46 AM »
Hi all,
I did search quite a bit for this on the forum but can't seem to find anything.  I am rebuilding a K4 and am nearly done. I bought new carb boots (carb to engine) from David Silver Spares, and upon reassembly, am finding that even clamped all the way down, the stock clamps "bottom out" before they are 100% tight.  Has anyone experienced this?  Worry is air leaks of course.
Thank you,
Marty
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline h2yamyk
Re: CB750K4 stock carb clamps - loose
« Reply #2 on: November 28, 2012, 03:46:00 PM »
I'd like to keep my stock clamps if possible as they're in good shape.  But nobody's are on the loose side, even tightened all the way up?  I am wondering if the david silver spares repro items are slightly thinner in design.
« Reply #3 on: November 28, 2012, 05:22:19 PM »
Then why not get the real thing, right from the source, item number 10: http://www.servicehonda.com/parts.html
Part number: 16223-KS5-000
The original ones get stretched out. I bought new ones a couple years ago, tightened up much better well before "bottoming out".
TAMTF...
Wilbur
Projects:
Offline cougar
  • Stamping Ground, Kentucky U.S.A.
« Reply #4 on: November 28, 2012, 05:33:07 PM »
Unless your trying to go "Concourse" restoration that's going to be for show, go with the clamps that "madmtnmotors" gave you in his first post. The clamps "Javahut" sells are FIRST class! Stainless steel, slight roll on edges (No cutting the boot) and since they're stainless they'll always look good. Good fellow to deal with as well as buy from. Just my opinion.   ...cougar...
I'm not prejudice, I'll weld anything that pays! Knowledge that is shared is Never Lost!!   Right is right, wrong is wrong! The truth is the truth and a lie is a lie! DEAL WITH IT ACCORDINGLY !!!   I HATE "DIAL-UP"
« Reply #5 on: November 29, 2012, 04:06:34 AM »
That's kind of how I was looking at it, a set of eight clamps for $16 with the first link, or a set of eight clamps for around $75 from Honda...
TAMTF...
Wilbur
Projects:
« Reply #6 on: November 29, 2012, 07:37:00 AM »
I always replace those clamps with better units on all my bikes. Between the old rubber shrinking etc they usually do not seal real well.I keep the old ones around incase I maybe sell the bike they can go with it.
Offline yesteryear
  • Long Live Rock n Roll
« Reply #7 on: November 29, 2012, 08:08:57 AM »
I too bought them from DS far to big ended up using the clamps for the air filter tubes do go on sweet just dont over tighten them,
Had no problems.Now I have 8 new ones gathering dust.
Cheers
Yesteryear
