Author Topic: 750 triple tree on a 650  (Read 1540 times)
Offline rab1dwolf
« on: July 10, 2006, 05:44:10 PM »
ok got my hands on a 1982 750 tree and seems to fit pretty good but my question was about ther bearings.
Mine had just ball bearings in grease but the 750 has cylindrical bearings in a collar.  I think those are better personally so I installed it with those.  Thing is that I can see a little of the bearing through a gap in the bottom of the tree between the tree and the neck of the frame its about a 1/4".  was thinking of making a dust cover that would fit over it.  Any ones have any ideas? or should i just go the ball bearing route?
1982 cb650sc nighthawk.  the work never stops.
Offline cb650
Re: 750 triple tree on a 650
« Reply #1 on: July 12, 2006, 05:08:02 AM »
Sounds like tapper bearings.  Did you change the races in the head?
                    Terry
Offline rab1dwolf
« Reply #2 on: July 12, 2006, 10:52:53 AM »
I didnt do anything to the head.  what exactly are races?
Offline dusterdude
« Reply #3 on: July 12, 2006, 12:12:32 PM »
http://www.federal-mogul.com/aftermarket/us/fm_bearings.htm?Country=USA&NumIm=1 the picture shows the bearing(cone) and the race(cup).the race goes in the frame to hold the bearings in place.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline cb650
« Reply #4 on: July 12, 2006, 08:10:31 PM »
Sounds like you need to swap races.  The races for the ball bearings are keeping the roller bearings from making good and proper contact.  Once you see the diff youll under stand.
                  Terry
