Author Topic: Drop-in headlight replacement for a '78k recommmendations  (Read 553 times)
fendersrule
« on: November 29, 2012, 08:12:49 AM »
Hi all,
My 78k's headlight has a loose part...some sort of a metal insight the lense. The headlight is also what I would consider pretty dim. I think it's just time to replace it.
What would you guys recommend for a good value headlight that would work well with a future modulator that I will install?
Re: Drop-in headlight replacement for a '78k recommmendations
« Reply #1 on: November 29, 2012, 08:17:44 AM »
7" H4 conversion lamp will drop in, allows you to change bulbs.
or, you can get sealed beam lamps
http://www.cb750supply.com/products/5/electrical/40/headlamps-headlamps-brackets-headlamp-parts
fendersrule
« Reply #2 on: November 29, 2012, 08:22:59 AM »
I take it the benefits of going with the H4:
1) Cheaper to replace the bulb in the future rather than replace the headlamp
2) Allows for flexibility while trying different bulbs
3) Brighter?
I assume you are refering to Part # 09-0072, which looks to be the only "drop in" H4.
« Last Edit: November 29, 2012, 08:25:42 AM by fendersrule »
« Reply #3 on: November 29, 2012, 08:44:48 AM »
^ yes to all of the above...
BUT, understand there will be an increased power draw.  your electrical system needs to be sorted or you may notice it dims at idle, and increases brightness with higher RPM
