Author Topic: Need Opinions on Bars and Taillight  (Read 1118 times)
Offline bartsitarski
« on: November 29, 2012, 01:45:28 PM »
Hey guys. I just ordered a new set of blubman handlebars for a 78 550. When i install these, is there anything special that i have to do in terms of brake lines, cable adjustments, etc? As is sits now, the bike is bone stock. I want to do mild tweeks to it, but, keep it mainly original. Also, any recomendations on a new taillight and rear turn signal combo while keeping original rear fender? I have founs a few on fleabay and amazon, but, wanted to get your thoughts.
Re: Need Opinions on Bars and Taillight
« Reply #1 on: November 29, 2012, 01:54:54 PM »
routing of all your cables may change due to the lower bars and the extra length.
i'd source shorter cables so they all tuck in nicely.
lucas style tail lights look nice.
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #2 on: November 29, 2012, 02:52:36 PM »
Cateye taillights tuck nicely into a small housing on the fender.  Small led turn signal lights look nice but require replacing the flasher unit, no biggie, just another $15.00.
Offline RFogelsong
« Reply #3 on: November 29, 2012, 03:09:36 PM »
You may have issues with the length of the front brake cable coming from the master.  I had some turn signals mounted on the headlight ears and they interfered with the stock length cable.  Plenty of people run stock throttle cables with clubmans.
I have a lucas style taillight with the stock fender and it's great.  Covers up all of the holes except for three tiny ones just back of the seat that I plugged with rubber stoppers.
-Rob
Hondas past/present:
SOHC1:'74 CB125, '78 XL125
DOHC2:'71 CB450K
SOHC4:'73 350F, '75 400F, '75 550K
DOHC4:'81 900F, '01 1100XX
V4:'85 VF1000R, '86 VF500F, '08 VFR800
Offline Bootlegger56
  • Butch
  • Nuthin' taps ya out quicker than cole corn likker!
« Reply #4 on: November 29, 2012, 06:33:58 PM »
I cut the front off of a stock 550K1 fender that I plugged and painted and installed a Lucas.   I like the look of it....but that's just my opinion.  I saved my good stock fender and bought a rust bucket to cut up and paint.  The Lucas fit the fender and seems to me to have the right size ratio for the style of the bike.
I didn't do the clubman thing opting for a cut down set of super bike bars.  For mine everything stock was too long and required replacing with shorter or judicious and creative routing.
Ya can travel near or ya can travel far; but no matter where ya go thar ya are!
750 K5
550 K1
Offline RFogelsong
« Reply #5 on: November 29, 2012, 09:49:03 PM »
OP:
For mounting a lucas taillight on a stock rear fender, imagine all those proportions in the photo above, just with about 12" of fender between the top of the taillight and the back of the seat.
Might help with visualization
-Rob
DOHC2:'71 CB450K
« Reply #6 on: November 30, 2012, 08:21:25 AM »
Thanks for all the input guys. Definitely helps!
Offline Jiminy Indy
« Reply #7 on: November 30, 2012, 08:26:40 AM »
Just a heads-up that when you put the clubmans on that you may have to adjust the fork stops so you don't dent in the side of your gas tank with the end of your bars. I just drilled a small hole through the stops on the trees and put a small bolt through.
Just a thought...
Of all the things I've lost, I miss my mind the most.
"Shot up the alley and then cut across the street" - now that's some violence you can appreciate!
Offline Chachi
« Reply #8 on: November 30, 2012, 09:16:16 AM »
These are direct fit with no fender mods. The package even includes hardware to fill left over holes from stock taillight mount. I was looking for a smaller taillight that I could install that would also allow me to easily switch back to stock. This one does and it's pretty nice. Glass lens for light too.
http://shop.noschoolchoppers.com/33cb-tail-light-package
http://www.lowbrowcustoms.com/index.php?l=product_detail&p=1036
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Bankerdanny
  • Endeavor to persevere
« Reply #9 on: November 30, 2012, 09:34:34 AM »
I was just about to say something similar to Jiminy. Clubmans look cool and the more forward stance helps with handling in my opinion.
However, you will lose some maneuverability because the bars will limit how far you can turn the front wheel. The first time I pulled away from a curb after installing cubmans on my Enfield I nearly got hit by an oncoming car because I couldn't turn sharply enough to stay out of the left lane.
I also had a small dent in the right side of my tank when the bike fell over and the bar hit the tank. If you look at racing bikes from the 50's and 60's you will see dents on both sides of the tanks to allow the bars to move farther side to side.
Offline RFogelsong
« Reply #10 on: December 02, 2012, 06:15:55 PM »
On the clubman clearance issues:
I have a $37 ebay set on my 550k (you should be able to find them pretty easily, there's one guy who sells 7/8" clubmans for $37 shipped) and I haven't had any clearance issues.  That said, my bars are rotated pretty far forward (not uncomfortable), but the tank clearance is prefect (about 1-2" between the controls and the "honda" emblem on the side of the tank when turned to the factory stop).  In fact, the last set of bars I had (same guy, same bars) actually protected the tank from being dented when some moron knocked it over, so that's kinda cool.  Bent the bars though, hence set #2.
-Rob
DOHC2:'71 CB450K
