Author Topic: Twin disc conversion  (Read 837 times)
Offline crankyrod
« on: November 30, 2012, 01:38:17 AM »
Hi I think I know the answer to this but hey why not take advantage of the wealth on knowledge here . Can you use the L/H side cb 750 K2 caliper bracket of the right hand side when converting to twin discs or does it have to be the r/h bracket which are getting hard to find now . I note the kick in the l/h bracket goes the wrong way when fitted to the r/h fork which would miss align the caliper.
Cheers
Dave
Offline Viktor.J
  • Breaking in the forum
Re: Twin disc conversion
« Reply #1 on: November 30, 2012, 02:05:59 AM »
There's alot writen here om The subject, search and you Will find. But if you have The early c-shaped forks you'll have to mill and use spacers to align The bracket With the right disc. I've done it and goong to start fitting it this weekend and going to write about it in my project thread so check in on that later if you dont want to search.
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
« Reply #2 on: November 30, 2012, 03:45:48 AM »
What Viktor says.
Here are my random pieces of information from my installation - but I used those later T brackets:
http://forums.sohc4.net/index.php?topic=110116.0;wap2
Offline crankyrod
« Reply #3 on: November 30, 2012, 04:32:26 AM »
Thanks for that I have the later t shaped bracket but its a left hander which has the kink off center pushing the caliper out of line I assume there is a r/h side bracket available?
« Reply #4 on: November 30, 2012, 05:06:56 AM »
I flipped the T bracket over and used spacers under mounting bolts to line the caliper up.
Not sure what you mean by kink.
