Author Topic: Choke cable measurements.  (Read 1051 times)
Offline Scott S
« on: November 30, 2012, 04:24:04 AM »
 Working on a 650 into a 500 swap and the VB44A carbs use a choke cable.
 I'm wondering if I can use a 550 or 750 choke cable. The stock 650 cable has a funky mount that uses the handle bar clamp. Not sure if that will for on the 500.
 Can anyone measure the total length and free length of a 550 and/or 750 choke cable for me?
 The stock cable for the 650 is approx. 37.5" long total length (including knob) with about 2" of free length at the end.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Choke cable measurements.
« Reply #1 on: November 30, 2012, 06:47:43 AM »
I have a 550 cable for those PD carbs plus a 79 CB650 cable. The outer cables are the same length, but the 650 piece (at least the 79 model with PD carbs) has a  +-1" longer inner cable.
You could use the 650 cable and 550 cable stay?
Offline Scott S
« Reply #2 on: November 30, 2012, 07:02:42 AM »
 This is exactly the kind of info I'm looking for! Thanks, Bwaller!
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #3 on: November 30, 2012, 07:03:50 AM »
 Well....I think so, anyway. I have the VB44A carbs....does anyone know if the choke cables are the same on all 650's?
 Off to Motogrid to check....
 EDIT: It looks like the '79-80 use one part #, 17950-426-000. The '81-82 use another part #, 17950-460-730.
 The measurement I have is from an '81, which is what I need. I wonder how much difference there is?
« Last Edit: November 30, 2012, 07:07:31 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #4 on: November 30, 2012, 07:49:32 AM »
 Also, am I correct in thinking that the free length is what really matters?
'71 CB500 K0
'81 Yamaha XS650
