Author Topic: What is the best way to detach & attach the throttle cable on a CB550?  (Read 1304 times)
Offline Two-Bit
I am working on the right control switch on my 1976 CB550 and have had to put the throttle cable on and off the throttle sleeve several times. I am getting it done, but it has been a pain in the ass every time I have to put it back on. I'm pretty sure I am not doing it right, so can someone tell me the proper way to do it. I've never been shown before. Thanks!
Offline goldarrow
  • one day, i'll be an
Re: What is the best way to detach & attach the throttle cable on a CB550?
« Reply #1 on: November 30, 2012, 10:31:04 PM »
Remove or lift up the tank, unhook throttle cable from carb, then throttle control should be easily remove from handle bar
CB550 K0
Offline thedrewski86
« Reply #2 on: December 01, 2012, 05:49:04 AM »
goldarrow is right, and the easiest way to get them off the carb is to back off the adjusting nuts a touch and slide the adj. shaft out of it's holder. Then the cable has plenty of play to come easily off the carb. There really shouldn't be any prying or difficulty whatsoever that way.
1975 CB 550k
1990 CBR1000f
1995 VT1100C2 (sold!)
2009 Ninja 250 (wife's)
1994 Toyota 4x4 22RE 5 speed
Offline Two-Bit
« Reply #3 on: December 01, 2012, 01:14:06 PM »
Thanks! I know it's probably motorcycle repair 101, but I haven't taken the class yet.  ;)
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #4 on: December 01, 2012, 01:19:02 PM »
It depends on if you want to put them back on.
If you don't, an angle grinder works fine.
If you do - then the only way is to pull the tank, disconnect 'em at the carb pull, and if you don't wanna bang or scratch anything as they swivel around (when you unscrew them from the bottom of the switch housing) , feed them back out so they hang away from the bike.
Just remember how they were routed so you don't end up with them binding as you near steering lock in either direction.
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
« Reply #5 on: December 02, 2012, 09:58:57 AM »
 10mm and 14 mm open end wrench..
