Author Topic: Exhaust and oil  (Read 1016 times)
Offline Uranium980
Exhaust and oil
« on: December 01, 2012, 06:51:39 AM »
Rode the bike the other day, looked at it last night, oil seemed to have dripped from the exhaust right by the gear selector. Has never happened before. Does this mean its blowing by oil, and an overhaul is needed? Checked the oil levels, everything looks good, no other leaks except for some seepage from the head.
Just picked the bike up and now rethinking my decision. Oy.
Re: Exhaust and oil
« Reply #1 on: December 01, 2012, 07:09:36 AM »
I see its your first post welcome.
Bike ID pls, yr, model etc. A little background. Stock, Modified, stock pipes, etc.
I suggest putting it (ID) in the Subject line, you'll get interested responders quicker.
Oil on the left side dripping may be from chain...depending on...
« Last Edit: December 01, 2012, 07:11:18 AM by MCRider »
Offline Uranium980
Exhaust and oil
« Reply #2 on: December 01, 2012, 07:10:55 AM »
It's a '79 cb650, my bad.
Offline Killer Canary
  • Typical Bran Muffin
Re: Exhaust and oil
« Reply #3 on: December 01, 2012, 08:07:17 AM »
Have a close look at the shifter seal.
Kawi GPz900, H1
Re: Exhaust and oil
« Reply #4 on: December 01, 2012, 08:22:21 AM »
Lot of good CB650 people here, I'm not one. Good luck.
(Put it in your subject line to alert browsers to the fact you are asking about CB650. Click "modify" on your post.)
Offline grasscutter
  • Love the CB650.
Re: Exhaust and oil
« Reply #5 on: December 01, 2012, 08:51:07 AM »
+1.
1-Take the side cover off. (will need to remove the shifter to do so)
2-Completely clean that area.
3-De-grease entire underside of engine as well.
4-Go ride.
5-When you see the leak again, go back to step one.
6-Find leak.
There are a few different o-rings under that cover.
Most likely is the shift shaft seal.  Then maybe oil pressure sender.  Or oil galley relief plug(s).
Worse case scenario is the case seal, behind the front sprocket.  Doesn't usually leak though.
Let us know what you find.
Come on!  We're burning daylight!
Offline Uranium980
Exhaust and oil
« Reply #6 on: December 01, 2012, 09:27:44 AM »
Awesome! Sounds like I got something to do Sunday.
Offline trueblue
Re: Exhaust and oil
« Reply #7 on: December 01, 2012, 11:30:37 AM »
What I have found as the most common source of leaks around that area on the 650's is the oil pump.  It has (off the top of my head) 4 o-rings that seal it, pull it off, strip it down and take it into your local bearing/seal shop they will be able to provide you with some new o-rings.  When I did mine it cost something like $2.  Make sure though that you tell them they are metric o-rings not SAE.
1979 CB650Z
