Author Topic: AMAZING Gas Tank Rust Removal Trick!  (Read 12618 times)
Offline 736cc
« on: December 03, 2012, 04:50:00 PM »
  I recently acquired a 1972 CB750 K2 w/ a perfect original paint gas tank, but the inside of the tank was solid heavy rust. Tried the usual agitating w/ a pile of nuts and bolts, then with WD40 but it still was really cruddy. I tried flushing a few times with degreaser then ran a tank of gas on the bike and ended up w/ a clogged petcock. So I tried the electrolysis technique for the 1st time and got AMAZING results! Here's what I did:
   NOTE: Toxic fumes occur during this process, so do it outdoors!
   Fill a plastic pail w/ hot water and add a container of table salt (bulk container comes in a typical $.99 cardboard cylinder). Mix well then dump into rusty gas tank. Topped-off gas tank w/ water from a garden hose. Plastic funnel in the filler neck. 12volt battery charger on 10amps. Negative to bare metal on tank. Positive clamp attaches to a valve spring and into the funnel submerged in the salty water. (IMPORTANT: DO NOT allow positive clamp or valve spring to touch any metal parts of the gas tank! The plastic funnel insulates the valve spring and positive clamp).
  Turn on battery charger, and water will percolate. You want 5 to 8 amps on the charger gauge, more salt brings the reading up.
Rust will bubble out of the tank in a steady stream (doesn't hurt paint). Tap the bottom of gas tank once in a while to loosen things up. 3 hours later, and a couple rinses w/ a degreaser, my tank was clean as a whistle. Dry it completely by rinsing w/ a bottle of rubbing alcohol.
« Last Edit: December 04, 2012, 05:59:30 AM by 736cc »
Offline Old Scrambler
Re: AMAZING Gas Tank Rust Removal Trick!
« Reply #1 on: December 03, 2012, 05:06:01 PM »
I like the spring idea.........going to attempt this on a few of my 'spare tanks'
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline hatchb4ck
« Reply #2 on: December 03, 2012, 05:17:21 PM »
That is a great idea.  Thanks for sharing your process and results.  I've got a couple of tanks that will need some rust removal.
Offline dusterdude
« Reply #3 on: December 03, 2012, 05:39:26 PM »
I used the works toilet cleaner on my sportster tank,worked like a charm
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #4 on: December 03, 2012, 06:23:22 PM »
Have a rusty one I should try this on
Offline Scott S
« Reply #5 on: December 03, 2012, 06:47:10 PM »
 I've used this method before but not with salt. It used washing soda or something? Can't remember right now.
 I've had great luck with The Works method, too. But not on super-duper rusty tanks.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Tews19
  • I am no
« Reply #6 on: December 03, 2012, 06:53:54 PM »
Can you post inside pics?
1970 Honda CB750 survivor.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #7 on: December 03, 2012, 09:08:25 PM »
Great tip.
I'd be interested in an inside shot too.
Offline singedebile
« Reply #8 on: December 03, 2012, 11:10:24 PM »
I'm curious did you end up coating the tank anyway? or was it so clean you didnt feel the need to?
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline pmurph1x
« Reply #9 on: December 04, 2012, 12:19:59 AM »
I've tried this with washing soda (1tbs per gallon) and about a foot of rebar. the results were disappointing. It cleaned the rust off some of the tank very well ( the area around the filler cap)but it left a lot of rust in pits towards the back of the tank. This was after 4 days and alternating the rebar from one side of the tank to the other.
   I'll have to try salt - maybe that works better.
Paul
Offline 736cc
« Reply #10 on: December 04, 2012, 05:53:52 AM »
Pics of the inside will have to wait because right now the tank is winterized and full of gas, marine stabilizer plus a couple ounces of 2 stroke oil. The transformation from solid rust to clean metal is remarkable. Getting rid of the unending loose grit which kept clogging the petcock made my day, rust just bubbled and floated out as really gross gritty fluids during the process. Tapping the underside w/ a hammer and directing the hose nozzle at full force into the neck speeded-up the process. I wouldn't describe the inside as brand-new, there's still dark spots, pit marks, areas that are grey and not shiny, but its CLEAN and the level of improvement is AMAZING.
Offline greenjeans
  • 1972 CB750K2
« Reply #11 on: December 04, 2012, 10:31:33 AM »
So...   what was the ratio of salt to water -   5 gallons water, how much salt ???
I've used washing powder before - it worked but took forever.
Offline 736cc
« Reply #12 on: December 04, 2012, 11:45:28 AM »
I used 30 oz of Morton salt in a stock CB750 tank filled to overflow. That gave a reading of 6 amps on my battery charger. I experimented w/ some junk iron to fit in the funnel and got much lower amp reading and salt ratio unchanged. I believe the valve spring conducted best so there's something to be said about that. A couple times I paused the process to flush the tank with a full pressure nozzle on the garden hose (great gobs of yuk disgourged) and I threw in some more salt and water as I resumed the electrical hydrolysis process. I think the rust was drawn to the valve spring and simply overflowed out the neck in the froth. Water was added when tank couldn't overflow, like every 15-20 minutes or so.
  It only took 3 or so hours. If I left it longer it probably woulda came out even cleaner but I was satisfied to what transformed.
« Last Edit: December 04, 2012, 11:50:59 AM by 736cc »
Offline lucky
« Reply #13 on: December 04, 2012, 02:59:29 PM »
Be careful to not smoke around the tank!!!
 Hydrogen gas gets produced with this method.
Offline Tews19
  • I am no
« Reply #14 on: December 04, 2012, 08:52:11 PM »
[/quote]
Bike looks sick!
Offline donny
« Reply #15 on: December 06, 2012, 04:41:31 PM »
 Back when this wuz new they guys prefered Borax.  Worked Okay for me.  Some of the "pros" put in a hand full of sheetrock nails and stuff in in the dryer, fluff only.
 Works great.
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline Vinhead1957
« Reply #16 on: December 06, 2012, 05:32:19 PM »
I am currently soaking my tank with a safe liquid Evapo Rust. I did use sheet rock screws to loosen the rust . My only problem is I have one gal in there and I have to migrate it to different areas in the tank. It is a long soaking process but the results so far are spotless
Offline dodieninja
« Reply #17 on: December 06, 2012, 07:24:22 PM »
can you l;eave the petcock on while doing this???
In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.
    Douglas Adams
Offline Vinhead1957
« Reply #18 on: December 06, 2012, 08:06:28 PM »
You could with Evapo rust
Offline 6adan
« Reply #19 on: December 07, 2012, 08:47:33 AM »
Insted of nails I use some chain with a string on it . It is easier to get out than the nails.
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline phil71
« Reply #20 on: December 07, 2012, 10:39:59 AM »
You have to take the petcock off. That metal will not take well to thi process. I've done this a few times, and I usually fabricate a block off plate of sheet metal, with a cut inner tube as a gasket. The petcock bolt holes also make a great grounding point for the neg electrode. One thing I'm curious about, I've tried iron, and it seems to work well.. The rebar gets slowly 'eaten', and from my understanding, it's re-plating the tank as it 'donates' its molecules . The spring, while dirty, and probably more conductive, doesn't seem to have given up anything..
I also have found that a battery charger alone does not work very well. Most battery chargers still have some AC ripple in them. I use a charger with a battery inline. This stablizes the DC current AND can supply more amperage, which may help when using a less-conductive metal.
Offline lostinthe202
  • Quality testing Elite 80's since 1978!
« Reply #21 on: December 07, 2012, 09:02:36 PM »
Nice addition, what type/size of battery?
How has everyone's (who's done this) experience with flash rust been?  How 'bout holes developing in the tanks since this is consuming metal?
'72 CB500
Offline luap
  • LAWL
« Reply #22 on: December 08, 2012, 08:46:47 AM »
Tried this last night. used a 12v 10amp charger. I tied 2 valves springs together after about a hr one spring was gone
so I switched to a piece of  1' round tube used the funnel on both. after a hr again or so pulled out the tube an it was almost eaten all the way. Tank def is getting cleaner going to do it a couple more times today switch out with clean water after each hours.
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #23 on: December 08, 2012, 09:32:00 AM »
I am going to give this a shot in the near future.  Unless there is a reason not to, I have some old forks springs I will cut down in length and use.
« Reply #24 on: December 08, 2012, 04:51:32 PM »
I've also done this method with nails (instead of the spring), which were cheap (like me!). It worked, but took about 30 hours total time, and 3 nails.
After it was done, I applied the POR-15 kit. Excellent results!
