Author Topic: How to get this out?  (Read 938 times)
Offline stereosilence
  • 1975 CB550K
« on: December 08, 2012, 05:15:41 PM »
I have this screw stuck under my alternator cover. I tried to get it out, then dremeled a slot and stripped that, then tried a screw extractor and it was too big (I think) and broke the head off. Any good ideas? I don't have a welder. Is my only option to try to get the smallest extractor I can and do that?
If Honda engineers were so smart, why did they think it was a good idea to use philips head screws?
Offline lucky
Re: How to get this out?
« Reply #1 on: December 08, 2012, 05:35:21 PM »
The phillips screws were a improvement over what we had.
A slot head screw was very frustrating to remove because the screw driver would not stay centered. A phillips screw driver would stay centered.
Also the single slot screw drivers came to a tapered wedge shape and did not fit into the slot properly like the earlier old time screw drivers.
The phillips screws are not a problem if the correct size phillips bit is used and an impact driver is used to loosen them.
Sometimes just a simple tap on the screw with a small ball peen hammer before loosening is all it takes.
Offline Old Scrambler
« Reply #2 on: December 08, 2012, 06:03:21 PM »
Several methods......drill with tiny tap.....then heat the case and freeze the broken cap-screw.  Take it to a welder.  File two flat-spots on each side of the screw and turn it loose with a small open-wrench.  Soak in penetrating fluid, cut a vertical slot near the base, then tap with a sharp tool to loosen. Try them all.......have fun.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
